Buying House with Septic System
   / Buying House with Septic System #1
HawkinsHollow
Veteran Member
SE TN
Branson 3015R
My in-laws are planning on buying a house with a septic system. I don't know anything about septic systems. When buying a house with a septic system is there a way to have a septic system inspected easily?
   / Buying House with Septic System #2
Yes and no….most lenders will insist on having the tank pumped prior to sale. But its near impossible to know if the leach field is compromised.
Maybe a record of tank maintenance would help. We have our tank pumped every 5 years. Its been running great for 30 years
   / Buying House with Septic System #3
Where I'm from, the septic system has to be inspected and pass a dye test by the county heath department prior to the sale of your home. My last home didn't pass and I had to buy the new owners an entire new system. They liked me very much.
   / Buying House with Septic System #4
My sister looked at a house and found that the 18 YO system had never been pumped.
That wasn't the deal breaker though. They also found that the tank was installed backwards. I'm no expert, but even I know that :poop: doesn't run uphill.
   / Buying House with Septic System #5
All the homes in my area are on septic tanks/fields. My system is over 60 years old. Only thing done with it in the 50 years I have lived here is pump it out every 4 to 5 years.
The one thing that seem to be most common with problems around here is the use of a sink garbage disposal. The next most problem causer is putting things down toilet that will not desolve. Big one is facial tissue.
Have In-laws require a pump out and inspection by a local company before closing. If local codes do not require it.
   / Buying House with Septic System #6
The only things that go into my septic tank are the three toilets. I've never even had mine pumped out.
   / Buying House with Septic System #7
Inspections are often offered by tank pumping companies.
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2018 Ford F-250 Reading Enclosed Service Truck (A55788)
2018 Ford F-250...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2011 Ford Ranger Ext. Cab Pickup Truck (A54814)
2011 Ford Ranger...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
Mini Standing Fire Pit (A55758)
Mini Standing Fire...
