Buying a snow blower for a john deere 110 backhoe
   / Buying a snow blower for a john deere 110 backhoe #1
LANGFORD
Burks Falls, Ontario, Canada
110 John Deere TLB
I have a new to me 2003 110 John Deere Backhoe
Was thinking of getting Pto snow blower
Any thoughts on what I should get.
Size, Name brand, What to look for in buying a used one
thanks
   / Buying a snow blower for a john deere 110 backhoe #2
Couple of things to look for:
* Impeller fan diameter - Bigger is better (bigger means faster tip speed which means less clogging and the snow is thrown further
* Number of impeller blades - More is better
* Ease of replacing shearbolts - If you have to take off 3 covers or don't have room to tap out a broken shearbolt you will be unhappy with it
* A power rotating chute and tilting deflector are much more convenient than their manual counterparts.
Aaron Z
   / Buying a snow blower for a john deere 110 backhoe #3
If me, I'd put a blade on the front.
   / Buying a snow blower for a john deere 110 backhoe #4
I've had a 60" Lucknow on the 3320 with good results for the last several years. I don't recall the specific HP of the 110, but you should be able to handle 72" - 84" range for most snow in your area. Have not had specific experience with other brands. You should be able to find a good Lucknow or Agrotrend on Kijiji at a decent price.
IMO Power Chute is a must. Deflector - I have not changed position of mine since acquisition, but have mostly open space to blow the snow.
   / Buying a snow blower for a john deere 110 backhoe #5
I have a new to me 1993 110 John Deere Backhoe
thanks
I think 2000 was the earliest 110tlb made so your tractor is newer than you think. I would go with a 7' rear blower for a little clearance. You have 33pto hp and a hydro so you should be fine.
   / Buying a snow blower for a john deere 110 backhoe #6
If you go with a 7' blower, make sure you have plenty of weight up front.
We have a 7' blower on our Kubota L3830 and when its on the 3 point, it makes the nose really light (to the point where you have to use split brakes to steer).
However, we don't have a loader on it, so with a heavy loader on the front you could be ok.
Aaron Z
   / Buying a snow blower for a john deere 110 backhoe #8
Aaron Z
When the OP removes the 1700 lb backhoe and switches to the blower he should be fine. The 110 has a fixed loader with ssqa bucket mount.
   / Buying a snow blower for a john deere 110 backhoe #10
billstmaxx had an interesting video about his JD 110 TLB. He had a snow blower on his fel. I know this is not what you want, I just found the video interesting.
1071 (A44391)
1071 (A44391)
2001 PETERBILT 378(INOPERABLE) (A45046)
2001 PETERBILT...
20 YARD ROLL OFF CONTAINER (A45046)
20 YARD ROLL OFF...
WINDLASS 5 HEAD (A45046)
WINDLASS 5 HEAD...
2024 VALLEY PIONEER QSP135 WHEELED MINI CRUSHER (A45046)
2024 VALLEY...
2017 GENIE GS-1930 SCISSOR LIFT (A45046)
2017 GENIE GS-1930...
