Buying Advice Buying a New JD with front end loader
   / Buying a New JD with front end loader #1
Mike 44
san antonio, tx
JD 3020, 450C bulldozer
I am in the market for a new JD with a front end loader and cab. I primarily do shredding with a 14 ' shredder. I will need around 100 hp. Are there an recommendations? Any to models stay away from?
I currently own a JD 3020 and a 450C bulldozer, I am have really been impressed with both tractors, and that is why I am starting my search with JD.
Any advice is appreciated.
   / Buying a New JD with front end loader #2
Today I got to try out a 6105M. I looked at the 6105D in the past and the transmission (no power shift) was a show stopper. When I had a 6M quoted a few years back it was significantly higher than the Kubota I ended up buying. One month after I purchased the Kubota JD came out with a program adding a free loader to the 6M that would have caused me to re-evaluate. For me, the 6 series is head and shoulders above the 5 series but it is also $$$$$.
   / Buying a New JD with front end loader #3
I know you have started your search with JD Mike, but if you want to give any thought to another color I recommend MF to you. I have a 4610 with a FEL. It has a power shuttle which makes loader work a dream. It is around 100 HP. It has a 3 cylinder which is very economical in fuel consumption. I pulled a 5-14 plow with it and burned between 1.5 and 2 gallons per hour. Put some fluid in the back tires and it will flat out pull. It also offers a very comfortable ride out in the field thus taking away the typical operator fatigue. I was able to get mine for right around 50k.
   / Buying a New JD with front end loader #4
I don't mean to be rude, but a 100 horsepower tractor pulling a 5 bottom plow using 1.5-2 gallons of diesel per hour seems way to good to be true.
   / Buying a New JD with front end loader #5
New or used?
If used avoid IVT gearbox in 20 series. Has internal solinoids on the gearbox. $6000.00 to replace a $200.00 part. JD 30 series has EXternal solinoids on ivt and I am told is much cheaper to repair.
Mike44, what is your fuel storage like? Do you run all fuel through a filter as you fill up? A modern (common rail engine) tractor does NOT tolerate fuel impurities like your older tech machines will. Just a factor that you need to be aware of when making your next purchase. ( A monkey of a worker caused $14k of damage to a friends 1 year tractor (100 hp)by not using filtered fuel when they ran out.)
Test the tractor under operational conditions and pay attention to the ergonomics. eg MF with a "dynashift 4" gearbox has an uncomfortable reach to the gearshift for me. A JD has an uncomfortable reach/angle on the 3rd scv control. No 1 scv gets the most use and with wear, (7000 hrs +) won't stay in float.. Change the scv couplings first as they are much cheaper and usually works. $1300.00 each to repair if the guts need to be replaced .
From what I can tell by internet searches they are pricey. Probably around $100 grand. But I bet they are nice
Thanks for you input.
Thank you for the input. I will check out your suggested model.
redman135. I am going to begin my search new. The filter tip is great. I get away with a lot with my old tractors fuel quality. I hope the dealers will give me a chance to try their tractors under field conditions.
1067 (A53342)
1067 (A53342)
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED (A54607)
2025 GREAT DANE...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
Mongo Mover Aluminum Hand Truck (A52377)
Mongo Mover...
2006 International 9400i (A55218)
2006 International...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
