Buying a Kubota - L3301 - Kind of late, but did I make any mistakes?
   / Buying a Kubota - L3301 - Kind of late, but did I make any mistakes? #1
RiseForms
Wakefield, NH
Nothing Yet - Soon Kubota
I'm buying a Kubota L3301 HST. W an LA 525 Loader/66" Quick Disconnect bucket, 4 Position valve and 3 point hitch. Decided on Ag tires - loaded with citrate - 23,400 for that.
Adding an engine block heater for the Northeast, a rear work light. Also adding Quick Disconnect forks for the front (heat with wood and pellets.. have a small farm growing here also.. and I can see me stabbing and grabbing/curling up brush with the pallet forks.
Adding a LandPride RCR1260 60" Rotary cutter for brush hogging in the back fields.
Adding a third function valve and Frostbite Grapple for the front.
I really was looking at doing a backhoe with thumb on back but sales guy really talked me out of it - I was looking to use it to hold trees/logs while I buck them up for firewood, drag felled trees around, dig up some boulders in the fields, do some stone wall maintenance on the property, etc. But he said I'd use it a couple times or few times an then want to sell it and for that price, I could rent a mini excavator every year for a couple weekends for 8 years and still not quite be even.
An attachment later will be a plow or a tiller as we learn more what we want to do with gardening after the first year here. And I'll be buying a snowblower attachment when they start getting manufactured again this summer.
Anybody think I'm going crazy here or missing anything?
Our property is about 22 Acres. 12 of those are pasture/field that haven't really had animals on them for about 35 years so a lot of brush hogging to do each year at first here. We have about 1 acre of what I would consider finish grass - and the Husqvarna lawn tractor will do there. Then the rest is woods and some wet woods/swampy areas. Property seems to really stay wet in a few spots - and soft.
We live here but we are also doing some small "hobby" farming on the side. We have a few sheep right now and their lambs, will be expanding that. Will be adding a couple beef critters over time and have about 100 chickens due to arrive fairly soon. I plan on harvesting firewood from the property and woods here and this summer's big chore is going to be cutting a lot of trees and brush down along the stone wall for the fence installer who is coming to put up a perimeter fencing around 10ish acres. Kids are still small enough that they aren't going to be holding any logs up and helping me move them around to saw bucks. I work full time in IT - and wanted to make processing firewood easier on my time (and back) and the stone wall needs some maintenance in spots, and I may give the grapple a try at some smaller logs. Plus we have a stream running through the far back woods and I'd like to clear some paths out to it and build a log bridge over it (not big at all, but just big enough to need a log bridge when the water is high in spring/late winter).
Did the Ag tires because I plan on entering the fields through gates we are putting into the fenceline along the road so I won't need to worry about hurting a finished lawn. Plus some of those mucky spots scare me a bit and the Ags give me a little more confidence. Plus I plan on having to shovel (with FEL) and Snowblow out to the chicken coop and the winter barn for the sheep and cows for feeding and watering - not terribly far distances and fairly flat, but like the idea of having the Ags for traction.
I was originally just doing the pallet forks - but at the last minute I asked them to add the third function valve and grapple - mostly because I feel like I'll want both eventually and I'd rather not pay to trailer it back to them to install the valve later (I'm not the most mechanically inclined person out there yet).
Also having them weld corner chain hooks on the bucket for some log and brush work and plan on throwing a shackle on the draw bar for dragging where needed.
And for the tilling vs plowing - I imagine us someday putting gardens in over about an acre and maybe planting a dozen fruit trees over the next couple years and a couple dozen fruit bushes. Nothing crazy.
   / Buying a Kubota - L3301 - Kind of late, but did I make any mistakes? #2
Welcome to TBN. I think your on the right track building and thinking about what you need and would like on your new Kubota. I had two other Kubota's before I ordered the Grand L 3540, I do agree with dealer about the backhoe as I had two hoes on the previous other Kubota's which were used less and less each time.Get at least one set of rear remotes that can be used for anything as top link or snow blower shoot rotation to box and black blade angles. The third function valve is also great to have if you want a grapple or a front snow plow to angle. Best of luck.
DevilDog
   / Buying a Kubota - L3301 - Kind of late, but did I make any mistakes? #3
You didn't make a bad choice. Whether or not it was the best one only time & experience will tell. I'm happy with my L3200 (same tractor minus emissions junk). Its a very good all around utility tractor. Bigger than those glorified lawnmower sized ones, but still maneuverable & reasonably priced.
   / Buying a Kubota - L3301 - Kind of late, but did I make any mistakes? #4
Welcome.
We bought the predecessor L3200 at MB Tractor in Tilton. Also decided to forego the backhoe, in part because the rocks I needed to move in the back yard were too big. Also got the Land Pride and the pallet forks, and a Wallenstein chipper.
We also have a brook running through and found advice on care and feeding of streams.Other than clearing brush from an existing logging trail, we've stayed away from the banks and left all the leaners and fallen trees right where Mother Nature left 'em!
   / Buying a Kubota - L3301 - Kind of late, but did I make any mistakes? #5
We need pictures!!!! Without pics it didn't happen.
Welcome.
Charlie
   / Buying a Kubota - L3301 - Kind of late, but did I make any mistakes? #6
It all seems reasonable to me. I think you will love the grapple for processing your fire wood. The sheep will do a lot of mowing and brush hogging for you if you move temporary fence around for them.
Yes pictures are a must. Keep us posted. :D
Pictures will come next Friday when it gets delivered. Looking forward to its arrival and learning my way around the tractor.
The sheep will definitely help with brush hogging over time. At first though we are starting with a fairly small flock - so it will be a few years before my rotational grazing ideas become a reality and they and the eventual couple cows turn that land back into pasture. In the meantime, I'll be playing "dodge the rock and hope the slip clutch and stump bump save my cutter" in the back fields - plus I plan on fixing some of the drainage the state of NH decided to culvert right through my property and see if I can't reclaim some of the wetter woods by running culvert/ditches to divert it further back.
I think right now as I look at all the trees I need to cut along the perimeter fence line , the grapple is the implement I'm most excited about, too Vtsnowedin ;-)
Thanks for the brook/stream tips, Garandman, we plan on leaving the immediate area mostly alone though we do plan on making a better foot bridge for the kiddos. I can slink across the leaners but don't want them doing that - at least not this time of year ;-) Plan on building a good backstop/hill for some target practice for the kiddos, speaking of your name, too :)
   / Buying a Kubota - L3301 - Kind of late, but did I make any mistakes? #8
My situation is very different, but I thought your choices were pretty good ones. Congratulations, and I believe you will enjoy your new tools! We do like our photos, too.
   / Buying a Kubota - L3301 - Kind of late, but did I make any mistakes? #9
Congrats on the upcoming arrival! I too am expecting a delivery next week of my L3901 HST to replace my older L2250 :cool2:. Sounds like we have similar terrain and I went with the loaded AG tires too. They have worked very well on my current tractor and would consider nothing else for my use..so I believe you made a good call there.
Sounds like you have outfitted yours very well :thumbsup:. I added a few extras too: work lights, block heater,hooks, and cruise control. Only suggestion is that you may want to consider the cruise control as you mentioned doing some tilling, plowing, brush hogging. My current tractor is gear drive and when brush hogging my fields it is convenient not to have to keep my foot on a pedal as I would with my new HST tractor.
Not a big deal about the hooks, but if they have not put them on yet, you may want to consider having them placed in line with the loader arms instead of the corners. Much has been posted here about bucket hooks and it seems most I saw recommended this particular location due to increased strength which makes sense.
Again, congrats on your new rig....looking forward to seeing the pics.
   / Buying a Kubota - L3301 - Kind of late, but did I make any mistakes? #10
I bought an inexpensive LED work light on eBay and tied it into the connector in the left fender. Works great and only draws 36w so I can use it with the tractor off if need be. Used some aluminum bar stock and some rectangular ubolts to mount it on the FEL.
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
JOHN DEERE 1050 TRACTOR (A51247)
JOHN DEERE 1050...
New/Unused 2025 CFG QK16R Mini Excavator (A51573)
New/Unused 2025...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
