Chipper Buying a Chippers
   / Buying a Chippers #1
johnnylight
upstate, New York
TC34DA
doing some research on chippers
What would you recomend for a TC34DA.
I got a price qoute for jinma for $1918.53 that includes shipping it to my door.
Wood Chippers, PTO Wood Chippers
the DR chipper for about the same a few hundred more.
woods for $3500.
I def need one renting would not work out for me--by the time I fin chipping I could own one at there renting price of $250 for the 12" $180 a day for the 6"
I have lots of brush and tree branches I do not want to burn.
any suggestions would be appreciated.
   / Buying a Chippers #2
John, I own a fair size parcel and an constantly chipping limbs & brush. Anything over 4" usually gets burnt unless it is in bad shape. I bought a Farm Pro (Chinese) chipper and have been pleased with it. It takes stuff up to 6" and has the auto feed. It's fun to put a 40' sapling into it, walk away and see it reduced to nothing. Outside of an occasional chip build-up or clog near the feeder belt, I've had no problems and would recommend it. I've cleared a couple of acres of saplings, so I've really run it through the paces. I bought mine for $1200 via Homier.com but just looked and see they don't appear to stock it anymore. They have a link to Farm Pro on their web-site though. I believe a Jinma (?) might be the same unit.
   / Buying a Chippers #3
I have a DR that came on a road ready trailer with lights and all. Yeah road ready... 45 mph limit. Anyway I haul it in the pick up if I go far. This self powered DR has been a great unit. I have no experience with PTO models but should share the same design plus a PTO drive gear box. IT is a great piece of gear and the support is terrific. You don'5t have to learn Chinese or such.
Pat
   / Buying a Chippers
I like that price.
would you consider used?
PatrickQ,
road ready that's sounds good -I like to go with a PTO for where am going on my property the tractor is the only way in and out (hills in some areas) or should i say up and down.
   / Buying a Chippers #5
woods for $3500.
You can contact me through my web site if you would like another qoute on A Jinma PTO driven wood Chipper.... 6 inch. In stock.
Email me your shipping info.....
Jinma Dealer, Ranch Hand Supply , Compact Jinma Tractors
Ronald
Ranch Hand Supply
   / Buying a Chippers #6
John:
I also own a Chinese 6" capacity wood chipper. It does everything I ever need it to do and have done many 6" logs.even forced 10 feet + of broken tops off my pines trees, it just eats em up.I lower it onto a small wodden cart when I don't need it and it stowes easily in the garage. I'm also in upstate new york.Spencerport.wanna come see it?
   / Buying a Chippers #7
I recently bought a Jinma 6" chipper in JD green of course. It has worked great. I did have to replace the belt on the drum feed for $10. Prior to buying mine, I rented a Vermeer 6" industrial version that you will typically see at rental yards. It was $180 for the weekend. My clearing project would have required renting it at least 3-4 more times in the next 4 months due to accessability. It was a hard decision, but I decided to pay $2000 in order to have one forever versus paying almost a grand for a few rentals over the course of 4 months. The Jinma worked just as well the Vermeer and mine was just about $2000 delivered to a freight terminal that was close by. Vermeer owners will probably go spastic when they see that claim, but there was no way I am going to pay $10,000 for a 6" Vermeer chipper when the Jinma was $2000. The Vermeer units are powered by a motor that is approx 25-30HP. Guess what, my tractor already has that size motor with a PTO ready to go. Both units can handle the same size material. The only real advantage to the Vermeer was the ability to rotate the chute. It is just as noisy and burns a lot of fuel.
I have access to it whenever I want without the 70 mile round trip to the rental yard. My neighbors all suggested burning. I would prefer to have a few cubic yards of free mulch anytime I am willing to fire it up for about an hour. Mulch is good. Burning is a waste.
The only things I burn are stumps and root masses with small rocks embedded in them or ones covered with excessive dirt. Most roots can be left out in the weather and after they get rained on a few times, they are then ready for the chipper since the dirt has been washed off.
You could always buy one, use it for a few months and then resell it. I don't think it would take long to resell if you priced it $500 less than what you paid. That would give you unlimited use for several months for $500. That is a huge bargain.
One last thing, a PTO powered unit can get into tighter spaces than a tow behind Vermeer. To me, that was a major factor. I take the tractor into the woods to where the materials to be chipped are located. The Vermeer would have had problems getting there. You can slip a lone tractor between trees pretty easily.
   / Buying a Chippers #8
So the going rate of the Jinma climbed from 1200$ to 2000$. It might still be a bargain but you're talking about nearly doubling in price.
Wow!
   / Buying a Chippers
Wow!
It's the shipping at $419. that's killing me.
it going for $1499 these days.
$1200. would be nice.
   / Buying a Chippers #10
johnnylight said:
I like that price.
John - I usually avoid USED powered items like a chipper. Never know how many stones, barbed wire & misc the unit chewed previously. I noticed on the Homier.com site, when you click on the FarmPro link and look at the attachments, they still show the chipper/shredder. There is a link on the top of the page to locate dealers - maybe you could give it a try. Good luck.
GODWIN (INOPERABLE) 3,500 PSI HYD. POWER PACK (A55745)
GODWIN...
2004 Volvo XC90 VAN (A55853)
2004 Volvo XC90...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2017 TROXEL 150...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
