Buying a Branson
   / Buying a Branson #1
okembalmer
Oklahoma
Hello. My name is Brent and I am new to TBN. I am looking at purchasing a new tractor. I just purchased 40 acres that has a lot of sapplings and cedar trees and hasn't been maintained in several years. I really like the compact tractors. Looking at all of them. Kinda leaning toward the Branson. Not sure how much HP, but kinda like the 4720. Any help would be appreciated.
   / Buying a Branson #2
Brent,
Evidently, there's a moderator who doesn't know that TBN has a Branson forum, and they moved your post here to All Other Brands! /forums/images/graemlins/shocked.gif
   / Buying a Branson #3
Bransons line of tractors are great. I'm not just saying that because I own one. But it is the reason I bought one. The 4720 should be a good size for 40ac. I would also check out the 6530. That tractor is awesome.
   / Buying a Branson #4
I bought a Branson 3510 back in May and I could not be happier with it. I have moved about 15 truck loads of dirt with it using a 5' box blade and the tractor has so much power. If I pick up too much dirt (box full, running over) the tractor dosen't bog, it will spin all 4 tires until I raise the blade a little. And that is in 2nd range, I haven't found a need for 1st range yet!
Also the warranty is very strong, 3 years/ 1000 hours.
I reccomend getting the R-4 tires too. ( Industrial) They have a wide foot print and make the tractor very stable. They are easy on grass but work great for compacting fresh dirt. I run a 5' finish mower with mine and the tires don't hurt the grass if it's not too wet.
As for size, That's a judgement call. 47 acres will make one shrink but a 4720 sounds about right.
If you can, look at the Chinese tractors and then look at the Branson. The quality is obvious in the Branson. tim
   / Buying a Branson #5
I have a Century 3045, which is the twin to the Branson 4720. Like you I also have 40 acres and it is just about perfect size for this amount of land. I have over 130 hours on the tractor now and still love it. Have a 6' foot brush hog, 6' box blade, 6' tiller and the C-86 backhoe for it and it easily runs all of these. Have been building a house for the past year with it and there are so many things I could not of done without it from the original land clearing, back filling, moving everything from lumber to bricks, digging what seemed like miles of trenches and of course maintaining the yard and keeping 3 different 1 acre deer plots going. Save yourself some money and buy the Branson. /forums/images/graemlins/cool.gif
   / Buying a Branson #6
Brent, Do yourself a favor and buy a name brand.I have had two Branson's and I regret not spending the $3000 more and having reliability. I first bought the 2810 model and had a bearing go out on the clutch, my front wheel drive had to be tightened on the caster, my starter sylynoid went out, my whole wiring harness burnt up, I had a hydraulic bearing go out and then I bought the 4020 model thinking that I needed a bigger unit that might be more durable. I have 7 acres that I bushhog and did some dirt work on and use my tractor for small jobs that I am hired to do, which is dirt work and bushhogging. I had to replace the fan b/c the tractor flexed causing the fan to push into the shroud, I had a hydraulic hose come apart on the power steering, my fuel tank neck is leaking, causing me to loose fuel, and the tractor blows so much heat towards the operator, after you are bushhogging or tilling for approximately 2 or more hours, that it is unbearable, especially in the Summer. I know all tractor brands have their problems, but I have had Kubota and New Holland and not near the problems.I do like the power and weight and the features, but if you can't use them then what good are they. At first I loved my Branson's, but it gets costly bringing it to the shop 45 miles one way, every month. Good luck on your decision...
   / Buying a Branson #7
Big_Lug
I tend to agree with you on buying a name brand. I have my Branson 4020 just over a year now with only about 62 hours on it.
It's a pretty face but not very reliable. I have to baby mine or it will blow hydraulic hoses as I have stated in other posts.
Dealer is next to impossible to get a hold of since he farms and has other irons in the fire besides tractors and is over 40 miles away.
He told me mine is working normal and I'm pushing it beyond it's limit...so no hydraulic problems as far as he is concerned.
Another minor problem I had in the beginning was when it rained the lights would start flashing and I had to disconnect the battery until it dried out. Not a big problem since now I keep it covered.
I like the tractor but it feels more like a toy. I plan on keeping it through the winter and possibly hope to unload it next spring or summer.
Brent if you are looking at Branson's consider Century...same tractor but their loader is much better, it works as it should, (I tried one out) not like an ansung does.(at least mine anyway)
Have a good day all,
Ron
   / Buying a Branson #8
Bought my 3510i this summer. Cleared a lot of fairly big trees and bladed land. Working the hydraulics to max digging stumps and no blown hoses. Sorry to hear others are having issues. I would buy another in a second.
   / Buying a Branson #9
The lights flashing when wet is an OLD problem--over two years. Your dealer should replace your flasher unit and/or the flasher switch. Insist that he do so, or contact the company.
   / Buying a Branson #10
Yalerider,
Glad to hear that yours is working good. Mine should be painted lemon yellow instead of Branson Red I think.
Just went out to look at it and it's leaking fuel out of the white plastic cylinder shape vent located underneath the seat area.
Tractor hasn't been started for a week. Loosened fuel cap to stop leak. What Next!!
Dealer said only a year warrenty on loader and I'm just over a year. I think he stalled around so now doesn't have to do anything about my hydraulics. Never another Branson!!
Good luck to other Branson owners,
Ron
2000 New Holland TN65 Tractor with Loader (A51573)
2000 New Holland...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
