Tires Buying a 5525, which tires to get?
   / Buying a 5525, which tires to get? #1
hollowcd
Getting ready to pull the trigger on a 5525 or 5625 in the very near future. I pretty much know the options that I want other than the tires. There are 3 options for the front, 11.2/24 - -12.4/24--13.6/24 and there are the 420/90 - -480/80R30 --15.5/38 options for the rear from what I can find. Ill be using this tractor for haying, with a decent amount of road travel. The ground where I am doing the haying is pretty soft stuff so I need to do what I can to help the rutting. Any opinions would be highly appreciated. Thanks in advance,
hollow
   / Buying a 5525, which tires to get? #2
I would go with the radial (R) rear tires. Larger footprint, better traction and tend to ride smoother because they are radial and generally operate at a lower pressure. Buy the larger radial if you worried about soft ground or compaction. A 480R is 18.9" wide and the 420 is 16.5" wide.
In the midsized and larger farm tractors, I don't even know if a non-radial tire is an option any more. Radials also have a longer road life than a bias tire.
   / Buying a 5525, which tires to get? #3
git the the biggest which would be the widest and give the highest top end for the road travel
2007 Ford Expedition EL Limited 4x4 SUV (A50324)
2007 Ford...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
Polaris 90 Sportsman 4-Wheeler (A50121)
Polaris 90...
Ez-Go Shuttle 2 Electric Golf Cart (A50121)
Ez-Go Shuttle 2...
