Tiller buying a 3ph tiller
   / buying a 3ph tiller #1
heehaw
Veteran Member
russellville, arkansas
Kubota M4900, B7510 and RTV
i am thinking about buying a 3ph rototiller, i can buy a used 4ft one for $700, i think its a land pride or something like that, it has been used very little, and looks almost good as new, but i want a 5 or maybe even a 6ft tiller. is it worth whatever the extra cost is going to be to get a ft or 2 wider tiller?
heehaw
   / buying a 3ph tiller #2
You will find much information concerning many different brands of 3 pt tillers on TBN. Just do a search on tillers. It is best to match the tiller to your needs and size of the tractor the tiller is going to be used on. Just because a 20 HP tractor can pick up a 82" 1200 Lbs tiller does not mean it has enough PTO HP to turn it in the soil. Most MFG have a recommended HP range of operation. It is a good idea to follow that recommendation. The next question is do you want chain drive or Gear drive side transmissions? There are no chains to break or chain adjusters to break or be readjusted in a Gear Drive Tiller.
   / buying a 3ph tiller #3
Look they painted that tiller just for the Christmas season. What no garland? /forums/images/graemlins/wink.gif
i have a 50hp kubota, so it should handle anything i can afford, the idea for a wider tiller is to till out the tire tracks, plus fewer passes. they are putting in a TSC here now, but it will be several months before its open, and i need to buy something, even if its not a tiller, before jan...
heehaw
   / buying a 3ph tiller #5
Re: Buying a 3ph tiller- What will it be used for?
What sort of soil conditions and how much / how fast? I think that will affect your choice of how heavy duty and how wide.
If you have that's not too tough and been tilled before, a lighter duty, wider tiller should be OK. I agree with following manufacturers' power recommedations - both minimum and maximum PTO HP. Wouldn't bother with an inexpensive light or "standard" duty tiller for anything less than perfect, easy soil in a smaller area. If the Landpride you're looking at is beefy, and is rated for your tractor's PTO HP, it's probably a good deal if you don't mind the size
We're breaking new ground in clayey soil with a fair number of small & medium sized cobbles; tillling in strips in some places, full beds in other places. Not a huge amount of tilling at any one time. We bought a heavy duty 50" side Befco T50 side shift unit for toughness and flexiblilty. Cost $2400 and should last 30 years or more. This was the best built heavy duty narrow tiller we could find in our part of eastern New York. I still managed to bend up one tine on a rock even though I was taking it easy.
I'm running a Kubota L4630, about your size. Two slow passes and plenty of rock picking and we've got new planting beds ready for amendments and the first year's crops.
Let us know what you're going to be working on. Good luck.
   / buying a 3ph tiller #6
I think a lot of TBN posters would agree that the First Choice is hard to beat for quality, value and parts availability after the sale--48-56-60-74 inch in stock and inexpensive delivery with free lift gate for easy offloading and no sales tax--Ken Sweet
Sweet Farm Equipment Co. *2003 Chamber of Commerce Business of the Year*
   / buying a 3ph tiller #7
With 50hp, you should be able to handle a 6ft. tiller. I have a 5ft behind my 33hp 1050 and it pulls it through heavy clay. It's a full load but the tractor doesn't lug.
i "think" i would prefer the heavy duty model, for the price difference, just looking at the difference in the weight, it has to be made a lot heavier..the local co-op sells an agri???
brand tiller, they are suppose to be getting me a price for a 70 inch heavy duty one...the main thing i have in mind, other than tilling an occasional garden, is to till up where i feed hay..it takes a long time for grass to come back at those locations, and i thought if i tilled it and put some grass seed on it, the results would be a lot better...
any idea what the shipping charges would be from where you folks are located??
heehaw
   / buying a 3ph tiller #10
Gonna find a lot of baler twine but anything else would find it too...
Kidd 450 Straw Chopper (A50774)
Kidd 450 Straw...
Electric Mobility Scooter (A51694)
Electric Mobility...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2016 FREIGHTLINER CASCADIA DAY CAB (A52141)
2016 FREIGHTLINER...
2006 Ford Expedition 4x4 SUV (A50324)
2006 Ford...
Toro Workman Utility Cart (A51694)
Toro Workman...
