bushog blade assembly
   / bushog blade assembly #1
eteagle
Illinois
JD 3300
I had been mowing, stopped and raised the bushog and the blade pan assembly, nut, washer and spacer came off. How do I put them back on?
Thank you
Ernie
   / bushog blade assembly #2
Before i spun the stump jumper / blade carrier back on.. I'd look over the nut and shaft, and threads / splines & hub to look for wear.. If the nut has -0- wear on it.. I'd re-use it.. otherwise get a new nut if it looks the least bit worn.
Check with your manufacturer for torqueing specs.
Soundguy
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
2011 TRAIL-EZE  TE80HT48 HYDRAULIC TRAIL (A50854)
2011 TRAIL-EZE...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
