Bushings for a new EA box blade and a iMatch
   / Bushings for a new EA box blade and a iMatch #1
Machinewars
Chapel hill, nc
CX2510
I just ordered a box blade from EA along with bushings for my iMatch.
5 Foot Xtreme Duty Compact Box Blade by Everything Attachments
The guy helping me said I would need to cut the bushings in order to use them with the clevis hitch pins and the iMatch.
Anyone know of a set I can buy online that would fit the above box blade without needing to be cut?
   / Bushings for a new EA box blade and a iMatch #2
What are the bushings made of? It might be no big deal to trim them down if they are rubber, plastic, etc.
   / Bushings for a new EA box blade and a iMatch #3
I assume you need. This for the lower pins. Tractor supply sells bushings to make cat 1 pins up to cat 2, and cat two up to cat 3 size. You will two of each. They cos a buck or two each.
   / Bushings for a new EA box blade and a iMatch #4
bought 2 yesterday at TSC $$2.29 ea
   / Bushings for a new EA box blade and a iMatch #5
I have found a few cat 1 to cat 3 bushings at my Deere dealer which would work for your clevis hitch. These are just shy of 2 inches long and have the 7/8 id x1 7/16 od. I also have bought the two bushings to step up from cat 1 to cat 3 as JRP mentions and is an easy fix.
   / Bushings for a new EA box blade and a iMatch #6
For most things I use cat 1 to cat 2 and cat 2 to cat 3 bushings and trim them to fit. I would prefer to have cat 1 to cat 3 (like the imatch comes with) but I have not seen any locally. Everytime I go to the tractor dealer I stock up on bushings, they waayyy less there than they are at TSC.
2009 International Ambulance (A49461)
2009 International...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2015 Chrysler 200 Limited Sedan (A48082)
2015 Chrysler 200...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
