bushings and pins on B20 Kubota
   / bushings and pins on B20 Kubota #1
Lopez
San Juan Islands, WA
YM155D
I have a great running B20 Kubota, but it's getting kind of sloppy. I have to replace the throw out bearing and rebuild the front end, so the TL420 loader has to come off anyway. I was thinking to throw the loader parts on the milling machine and bore out the bushings to round, and then weld in bushings with standard I. D., then ream to size if necessary. Seems like a lot of work (well, fun, really), but I can't think of a better way. Same situation with the BT 750 hoe. Is this the right approach?
Thanks,
Don (on Lopez Island)
   / bushings and pins on B20 Kubota #2
Right? Well, that depends. I thought that the tractor had replaceable bushings. Just press them out and press in new ones. Are they brass or steel? Baum Hydraulic has both brass and hardened steel split tension bushings. Best price I have found.
jb
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2013 JOHN DEERE 8235R LOT IDENTIFIER 191 (A53084)
2013 JOHN DEERE...
2022 BOBCAT T64 R-SERIES SKID STEER (A51246)
2022 BOBCAT T64...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 46 (A53084)
2020 JOHN DEERE...
