canoetrpr
Veteran Member
- Joined
- Aug 7, 2005
- Messages
- 2,396
- Location
- Ontario, Canada
- Tractor
- Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
Just got my new Pats CAT2 slide in hooks on my M7040. I've got to go get some bushings for my CAT 1 implements (which is basically all of them).
Something I didn't think of is: The bushings for CAT 2 to 1 that I can seem to find on the internet all seem to be some standard length (1 3/8" or 1 3/4"). I won't be able to prevent such a bushing moving round once it is put over the lower lift arm pins on an implement will I?
Trying to figure out how I will be able to get the Pat's hooks over these things if they are going to move around.
I guess even if it does not move around, they are going to be much smaller than the lower lift arm pins on the implements. One of the nice thing about the Pats is that I find the lower lift arms do not have to be exactly the right width and it allows a little bit of play to get the implement hooked up.
Any thoughts?
Any thoughts?
