Bushhoggin underbrush
   / Bushhoggin underbrush #1
RMEADOWS
Bronze Member
Lakeland, Fl
MF 1428
I'm in the process of clearing 7 arcres or underbrush and scrubs from the wooded area of my property. Basically, I'm cutting out most everthing under 3", with a few exceptions.
I have some very heavy brush, higher than my head in the tractro seat. It's all very thin stalks, but weaved together and interspursed with vines (with thorns). I hate vines!
What is the best way to cut through this. I tried backing an intiatial trail, but I get hung up more that way and the thicker stuff. When I drive in, my body get caught up in the vines. I really like my head being attached to my body.
Any suggustions?
   / Bushhoggin underbrush #2
Do you have a fel? I've found if I put the bucket low and drive in forward I can push everything over and drive over it until the blades hit it. If it's too heavy for me to drive over then it's also probably too heavy for my bushog to cut too so it's kind of a built in safety system. If it's just too viny you could try either a toothbar on the loader or a brush brute and rip out the thicker stuff. Without a fel I think you're in for a tough time.
   / Bushhoggin underbrush #3
I don't like stuff that high raking the underneath of my tractor, so I back in. But only about to the middle or front of my rear wheels. Then I pull out, move over, and do it again. I repeat until I have cut a wide swath and go back and start over. If I go forward, I keep the FEL low to push over/down as much stuff as possible before I pass over/thru it.
If you are cutting everything and it is fairly clear of large stuff, you may be able to make parallel passes along the cleared edge cutting only about half a cutter width at a time to keep from getting tangled and hit so much.
   / Bushhoggin underbrush #4
I am regularly in blackberries and salmon berry brush up to twelve foot deep. I use my loader to pat them down as I go. I keep the loader up push down as I go keeping the bucket curled back so it will slide easier. I do have a belly pan to protect the tractor. I would suggest that you do not back up on brush that you have pushed over. Take an edge with the brush to your right if you can, the mower is able to get rid of what it cuts more readily. I take a half cut if it is tough going, I can look at what is going by incase there might be something I might want to avoide on the next pass. As far as those wait a minute vines, I liken it to fighting a bees nest, don't go in there if you don't want to get stung. Might laugh at this one, wear a full face motorcycle helmet. Has kept my nose and ears from turning red. Have fun, I love to mow briars.
   / Bushhoggin underbrush #5
My Satoh is almost identical PTO hp to your Kubota (22.5)… and cutting “thick” brush is quite a challenge… If you have lots of time and patience, you’ll eventually get it done in time to start over and be a perpetual thing with your 7 acres… /w3tcompact/icons/blush.gif
What you may want to consider is “renting” a 50-60 PTO hp unit… going in to get the job done and over with… and then maintain it with your Kubota… believe me… I’ve got 157 acres and my 50 hp JD is a workhorse… but she can’t keep up… so I’m ready to buy a second 75-90 hp unit and “scare” all those vines and small trees away… /w3tcompact/icons/wink.gif
   / Bushhoggin underbrush #6
I just recently got done cutting 10 ac of my pasture that had about 10% tall thin grass, 10" briars, and 40% tall thick ( 7' ) dog fennel, and 40 % tall thick ragweed.
I cut it with my NH 1920 and 5' cutter. I just drove over it. There were very occasional 1-1.5" saplings..
I fabricated a front bumper to keep weeds from tangling, but had to stop every 20 minutes to clean the pre-filter on the radiator.
Cut fine, ran fine in 3rd range 1st or 2nd gear.
Soundguy
   / Bushhoggin underbrush #7
I know this won't help your situation, but I have a front mounted brush hog and go through similar stuff with ease. <A target="_blank" HREF=http://users.beanstalk.net/godollei/pt425/PT425Videos/PT425DeepWeeds1.WMV> Here's a link to a movie</A> of what it looks like from my driver's seat.(low quality and takes a couple minutes to load, but fun to watch if you have the time)
Back to your question, a rear mounted brush hog is hard to use in tall stuff unless you can either do what everyone else does and mash it down with the FEL first, or just back into it all day(hard on the neck). /w3tcompact/icons/mad.gif
   / Bushhoggin underbrush #8
Is that your thumb at the end of the movie?/w3tcompact/icons/laugh.gif
   / Bushhoggin underbrush #10
Yeah, that's my thumb. /w3tcompact/icons/laugh.gif I would have given it two thumbs up, but one hand was holding the video camera. /w3tcompact/icons/tongue.gif
I've got a few more video links out there on TBN somewhere. That front mounted brush hog is just plain fun to use. If you liked that video then <A target="_blank" HREF=http://users.beanstalk.net/godollei/pt425/PT425Videos/PT425MultiFloraRose.WMV> Click here to prune a multi flora rose bush.</A> /w3tcompact/icons/shocked.gif (same deal as before, kind of grainy and takes a few minutes to download, but fun to watch and listen to that hydraulic whine.)
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2002 Trotwood Trailer (A50515)
2002 Trotwood...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2014 BMW 328i Sedan (A50324)
2014 BMW 328i...
2016 Dodge Ram 2500 (A50120)
2016 Dodge Ram...
