Bushhog Vibration
/ Bushhog Vibration #1
rdam
North Florida
Kubota 3240 DT
I have an L3230, 8x8 shuttle with a 5 foot BushHog brand "Squealer". The BH is vibrating excessively at PTO speed, as if the blades were unbalanced. It is not consistent. It may smooth out for awhile, and after shutting down the PTO, and then re-starting a few minutes later, the vibration will be bad. All looks in order underneath. The driveshaft is attached to the PTO properly. The blades swing on the pan "relatively" easily. Cutting low, with the skids almost touching the ground, seems to smooth things out??? Prior experience with a 6 foot "Squealer" was excellent, with little if any vibration. Any ideas what to check?
/ Bushhog Vibration #2
You say it "looks" in order underneath. Did you check to make sure the blade bolts and nuts are tight? You did say the blades seem to swing "relatively" easily on the pan. Were they both the same? Sometimes when you stop, one blade may swing inward which throws things out of balance when you start again until the cutter gets up to speed and swings that blade back out straight.
/ Bushhog Vibration #3
I have a Squealer 48 and had the same symptoms. Ended up being a 1'"x2" chunk missing from the stump jumper (mine is football shaped) on one blade side. I cut the same size chung out of the opposite side and the vibration ceased. My suggestion is check your stump jumper carefully for missing pieces. I have not had any problems since I cut out a opposite piece.
/ Bushhog Vibration #4
rdam:
Solid advise so far. I would grease the pivot points where the blades attach to the stump jumper/blade pan so that they swing freely. I would also check your blades for missing material. It does not take alot of "misbalance" between blades to make for vibration when running at speed. Jay
/ Bushhog Vibration #5
Jay has a good one there. I broke a blade in 1/2 and that made it shake a bit. Not as much as you may imagine, but lot's more than normal.
Sticks also hold the blades on the inside of the jumper and thay makes it shake bad.
A bent blade may hit the deck or the jumper and get hung up. Use a ruler and check distance from the blade tip to the deck. Might as well check the distance from the pivot to the end of the blades too. Then check the distance from the jumper to the deck as you spin it 360 to make sure the shaft from the gear box isn't bent.
jb
/ Bushhog Vibration #6
I had exactly the same symptoms with my Bush Hog. The blade bolts go through the blade, then the stump jumper, then through the blade bar. The stump jumper's metal had broken out around where the bolts went through it, and it was shifting around and not staying centered. When centered, there was no vibration, but when off center it vibrated a lot.
The problem wasn't obvious when I first looked underneath. You might want to take a closer look to see if you have that problem.
/ Bushhog Vibration #7
/ Bushhog Vibration #8
I have experience the same thing but with a JD LX4 - Just yesterday i started the pto and it had a slight vibration.. I ran it for a while and it seemed to be cutting OK.. But I stopped and let the cutter spin down and when I restarted the PTO the vibration was gone.. I think one of the blade had gotten stuck..
Brian
/ Bushhog Vibration #9
Brian
Thatguy:
That is the first thing I do whenever I get the "shakes" (on my tractor that is) :rolleyes:. Jay
/ Bushhog Vibration #10
Sounds like one of the blades was stuck partially folded up.
/ Bushhog Vibration #11
After reading this thread I realize what happens to my bush hog and why what I do stops the shaking. When I hit something big enough to fold one of my blades, it shakes until I dislodge whatever it is by raising or lowering or by moving forward or backward. It happens often because most of what I cut is 1 inch and bigger trees.
/ Bushhog Vibration #12
Actually, it is probably NOT one of the blades folding up, at least on the newer Squealers.
You can prove this by letting the tractor/mower keep running in a high vibe condition, then gently throttle down, and then shutting off the tractor. If your mower is high enough off the ground, perhaps a foot or so, you can look under the mower and see that the blades don't fold up. (Obviously, the tractor and mower is completely stopped when you peer underneath and put a concrete block under it or use a mirror).
However, if you mark the PTO / slip clutch as I described in an earlier post, you can verify that the high vibes will typically occur when the slip clutch is in a certain "number to dot" orientation.
You folks that say "...the blade is folded up", do you have a shear pin or a slip clutch drive on your mowers?
I had a shear pin mower once and I never got an intermittant vibration, like I do with my a slip clutch mower....
dwight
/ Bushhog Vibration
OK. Lot's of things to check, including the "out of sync" slip clutch theory. I'm working the weekend and will check on Monday.
/ Bushhog Vibration #14
dwight
Dwight
My Squealer has the slip clutch. It's a little over 3 years old. Most of that time I assumed like the owners manual said that the slip clutch was adjusted properly. Well I went about my business cutting brush and occasionaly having my tractor completly go dead due to the bush hog stopping when I hit a stump or rock. I also had the vibration at times. After all the comments about the L2800 pto I decided to adjust the clutch. It will slip now and not bog the motor at all and it still vibrates at times.
/ Bushhog Vibration #15
I can tell you that I used a pair of vernier calipers to set my clutch spring tension dimension, as the owners manual describes. (And the condition did not improve).
With all Ive said, you should consider the other possibilities, like the folded blade theory. It's just that with my Squealer, I could not verify the folded blade theory. That's why I began to look elsewhere...I can tell you that the vibe condition always appeared when I hit something hard, like a sapling or whenever I engaged the mower, even at low RPM's.
But your experience may be different than mine. I sure would like to learn more about this, if you have additional insight....Im all ears!
Let us know what you finally discover.
dwight
/ Bushhog Vibration #16
dwight
It doesn't matter whether it has a shear pin or a slip clutch. If when the mower is stopped, one of the blade spins back around into the stump jumper, a blade can jam there. I have seen several do that. Usually, when they start they will straighten out but sometimes they don't until the mower is stopped and restarted.
/ Bushhog Vibration #17
JerryG.
Thanks for your input, but I didn't know you owned a 5 ft Squealer, Bush Hog brand rotary cutter...
Ive got more than 600 hours on my Bush Hog Squealer and have NEVER have jammed a blade. Other mowers, yes, Ive jammed blades, but not my Squealer.
The original poster (rdam) specifically said the blade was NOT folded up...
So you seemed to miss my point. So I'll say it again.
If the mower is checked for a jammed blade and it is free, then the mower slip clutch can be the source of imbalance, if it has one.
dwight
/ Bushhog Vibration #18
Theowegian said:
JerryG.
dwight
It doesn't matter whether it is a Squealer or a Joe's garage model or even how many hours there is on a mower. Some mowers do it every once in a while and some never do. It seems to have more do with the length of blades relative to the diameter of the stump jumper. These lengths vary even in the same model as the size of the mower changes. Even if a blade is folded up, it may straighten out when it starts. They can also unfold when they stop but that seems to happen less often. The OP said that everything look fine when he looked under there. We don't know where the blades were before he stopped.
rdam,
Check your blade bolts to see if they are tight. If one of the nuts are a couple of threads or more lose, it will cause a vibration and can cause blade jam. It doesn’t always cause a blade jam but almost always cause vibrations. There are of course other things to check. PTO shaft: check to see if the u-joints are good, check to see if the shaft is straight, See if the PTO shaft is snug on the gear box. The last thing that I would check if every thing else is ok, is the stump jumper nut.
Good luck.
/ Bushhog Vibration #19
I agree with JerryG. RC's should be "well balanced" at the time of purchase. It does not take much to throw one off. Jay
/ Bushhog Vibration #20
Also, make sure both blades are installed the same way (hanging downward). One time somebody, who shall remain nameless and was in a hurry, installed one of the blades on my bush hog "upside down." Talk about vibrations....
2015 VOLVO L30GS WHEEL LOADER (A65053)
2015 VOLVO L30GS...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
