Front-End Loader Bushhog front end loader grease fittings
   / Bushhog front end loader grease fittings #1
rdrawdy
I have a Bushhog 3545 front end loader that is missing some grease fittings. I can't seem to find anything to tell me if these are threaded or tap-in or what size. Anyone know what size and type to use?
   / Bushhog front end loader grease fittings #2
Drive in fittings fit into a plain bore. Threaded grease fittings require that the bushing they screw into have threads as well. The bushings will either have threads or they won't. If the bushings that are lacking zerks have threads, remove one of the remaining zerks, check to see if they match the holes for the missing fittings, and take the zerk to a retailer to match what you need.
   / Bushhog front end loader grease fittings #3
You can find parts manuals for your 3045 here: Discontinued model Manuals. There are three of them, in the right hand column at the end of the page. They will give you the Bush Hog parts numbers you need if you want to order them from your dealer. Or you can just have the parts guys look them up for you.
Thank you both for your help. GreenWannabe, your link has some great info/diagrams that I did not have and hadn't been able to find. I found exactly what I needed for the grease fittings, but also now have a great reference for future needs. Thanks a lot!
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52128)
John Deere 1110...
2009 GREAT DANE 53FT REEFER TRAILER (A52141)
2009 GREAT DANE...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
10' Unused Feed Bunk (A50515)
10' Unused Feed...
