bushhog abuse?
/ bushhog abuse? #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
Hello everyone. Hope everyone had a good weekend. I own a JD 5103 with a 6' bushhog. It is a mid-duty hog, model #286. My wife and I just purchased an additional 14 acres this summer and lately I have been cutting some of the brush with my bushhog. The property is planted mostly in plantation pine but does have some spots where the youpan is pretty thick. Some trunks of these bushes are about 2-3" in diameter. The tractor and bushhog seem to handle it fine, I just want to be sure I do not tear up my bushhog b/c it is all I have right now to keep my place cut. This brush is very flexible and cuts in a couple good swings with an axe, so I figured it is harmless for the bushhog. There is some of it I won't cut b/c I am not sure how the bushhog will handle it. Rather be safe than sorry. Any advice on the limits of this cutter would be great. I've visited the bushhog sight and read the specs. I'm looking for user experiences here. Thanks in advance for any help.
/ bushhog abuse? #2
Not sure what type of cutter it is.. but in general.. 1.5-2" 'woody' material is ok, and 2"-3" 'green' material is ok.. as long as the tractor is not bogging down.. or other problems aris.. like the hog jumping.. or shear pins popping / clutch slipping. For the flexible stuff like you describe.. many tractor owners use the genral rul of thumb that if they can get thier front axle over it, and it doesn't bog the tractor down while chewing it up.. it's an acceptable load.
If I mowed that stuff all day / every day.. I'd want a HD cutter. If it was a infrequent occourance.. I think you are good to go.
Soundguy
/ bushhog abuse? #3
Sounds like you are making the right calls regards the limits of your bush hog and its doing fine.
When you feel like you want to gamble, then venture into those bigger stems, but realize it is a gamble and you might find the 'weakest link' that will have to be fixed.
Is it worth it? Sounds like it is not, and cutting some bigger stems by hand is a better route for you. Also, depends on the species of tree or bush that make up these stems. Some are stronger and denser than others. It's your call. /forums/images/graemlins/wink.gif
/ bushhog abuse? #4
I'm planning to embark on the same thing; rows of pine with yaupon in between. I have a Kubota L2800 with a 5' rear cutter, and had thought that slowly backing over the yaupon for the first pass might be the best. If any damage occurs, it would probably only be the shear pin, and going slow would allow the blades time to cut through the larger stuff without overloading anything.
The next question I had was what about tire punctures? Is this something I need to worry about, or are the AG tires generally beefy enough to handle rolling over small cut off stumps?
Regards,
Just Gary
/ bushhog abuse?
thanks for the input....rotary cutters seem to only be going up in price and i would like to keep this one a while! /forums/images/graemlins/grin.gif
/ bushhog abuse?
I have ag tires and have not punctured one yet. The youpan seems to be soft enough that the tractor smashes it down before it punctures a tire.
/ bushhog abuse? #7
Deerefan,
3" is within the range of a medium duty cutter and 50hp tractor. Yaupon is as hard as oak, but cutting green 3" trees should be no problem if you go slow. Keeping your blades sharp helps a lot too.
/ bushhog abuse? #8
Just guessing but for Clarifgication
Youpon being Yaupon Holly ?
Ilex vomitoria is the botanical name. Can get to be a fairly large specimen. The dwarf variety Ilex vomitoria 'nana' is a medium bush seen around home foundations maxing out at a typical size of 5' but most often seen in the 3-4' range.
Anyway at 2-3" thick as I am sure you have experienced this is a fairly soft wood. Probaby splinters more than it cuts.
It is similar to privet when it is the size you discusion. Be careful, it can and will resprout. The thicker/old stumps can get very tough.
Good news is that it is not as hardy as privet and easier to kill.
/ bushhog abuse?
I am not sure of the exact name. People here call it a few things (some of which I won't repeat /forums/images/graemlins/wink.gif) It is commonly called youpan. Others call it privet. It does splinter, it is a very flexible type wood.
/ bushhog abuse? #10
I'm familiar with the bushhog model 286. I own one. As you said, it's rated by Bushhog as a "medium duty", but that's a relative term. You can destroy any implement, but the 286 is a pretty tough hog. I prefer to raise the cutter and back it over the larger bushes, then lower to cut. This helps to protect the undercarriage/wiring/fuel lines, etc of the tractor from the brush.
I cleared an adjoining pasture a few years ago for an old uncle that was full of large native bushes, some with 6" stumps at the base, with no problems. Just took my time and cut slowly.
/ bushhog abuse? #11
In my case, Yaupon Holly is exactly what I'm talking about. Yes, it does resprout after getting cut back, but tends to shrub more than just make another large trunk. The ball of the shrub does get large, like you said.
If I can get through it one time without tearing up the equipment, I figure I'm home free after that, since I just need to provide discouragement in the future. My only problem is the size of the area I need to discourage...
When I get a chance I'll give it a try. Thanks for the tips.
- Just Gary
/ bushhog abuse? #12
I assume your manual, as well as Bush Hog's website, show the rating for your rotary cutter, which for the 286 is 2" material. Personally, I wouldn't be concerned if some of the material is 3" diameter.
/ bushhog abuse? #13
I've used my heavy duty Landpride 6' rotary cutter on 2+ brush and small trees...BUT, I sure do hate the sound it makes!!! Sounds like a magnitude 7.8 earthquake!! I try to avoid such obstacles.
/ bushhog abuse? #14
My Med. duty Woods Brushbull 720 is supposedly rated for 2" woody material. It handles it OK. Bushy plants with multiple 1" to 2" stems make it work pretty hard....you can smell the slip clutch. Single stem, up to 2", appears to be no problem. Occasionally something 3" in diameter goes through. The 3 inchers make a heckuva thump and bog the tractor a bit, but I'm usually through it before I can do anything.
As said above, keep the blades sharp and go slow in the heavy stuff. It's the rocks and the stumps that do the damage.
Bob
/ bushhog abuse? #15
</font><font color="blue" class="small">( BUT, I sure do hate the sound it makes )</font>
Fist time I hooked and knocked over a 3" ( 10' tall ) flexible green sweetgum sapling with my 10' mower I knew i had run over something too! /forums/images/graemlins/shocked.gif
Soundguy
/ bushhog abuse?
I used to cut w/out hearing protection. Got off in some brush and clipped a thick branch on the ground. My ears began ringing. Definitely wear the ear protection now. /forums/images/graemlins/grin.gif
/ bushhog abuse? #18
I haven't found anything I could run over that would hurt the rotary cutter, but have had some saplings fight back and spear the radiator ...ugh
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2012 LincolnMKX Hybird Sedan (A61574)
2012 LincolnMKX...
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
