bush hog zero turn
   / bush hog zero turn #1
polkwrangler
lakeland florida
1997 L35 kubota
turn the key on I hear a click, turn the key more to start nothing...new battery all cables great newer starter.could this be a solenoid issue ?
   / bush hog zero turn #2
Easy thing to check first are any safety switches. I had wires on my Ferris ZT seat switch come apart once, so it wouldn稚 start. Spliced them back together and good to go
   / bush hog zero turn #3
Start by using a volt meter connected between the small terminal on the starter solenoid and turn the key to start and see if you have 12 volts. If 12 volt then I would suspect starter if this is the 3 terminal solenoid. If four terminal and you have 12 volts at the solenoid then start checking the pto switch, the safety switches on both levers, and the parking brake switch. On some more also need to activate the seat switch to start. If you have the three terminal solenoid and don't have 12 volts then go through all the safety systems.
thanks for the help,it was a loose safety swith
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
1987 Ford F-250 Wrecker Tow Truck (A51692)
1987 Ford F-250...
UNUSED Safety Traffic Cones (A53117)
UNUSED Safety...
