Bush Hog Squealer
   / Bush Hog Squealer #41
<font color="blue"> (SQ84T) the blade tip speed is 11,500 fpm where as the SQ720 blade tip speed is 14,963. I wonder what makes the blade speed so much different? </font>
The 84T has 2 sets of blades?? If that's right, then each set of blades will be about 42" diameter, tip to tip. The 720 single spindle set-up will be about 72" diameter. If the 84T gearbox doesn't turn the blades at a significantly higher rpm, the larger diameter model will have the higher tip speed.
If my numbers are right, the 84T is turning about 30% more rpm than the 720. The smaller blade diameter, however, translates into slower tip speed, despite the higher rpm.
Just a guess.
OkieG
   / Bush Hog Squealer #42
I have the sq720 with a slip clutch, on a New Holland TC29
It works great, it's just a little bit wider then the tractor and that makes it easy to guide in small places. I will tell you that look at buying a finish mower first, unless you will be cutting alot off brush. A field cut with a finish mower looks better.
   / Bush Hog Squealer #43
</font><font color="blue" class="small">( woof,
What is an LK3054? I don't get out much, so pardon my ignorance.
)</font>
AN LK3054 is a 30 hp Kioti. They are Korean and usually sell with more standard options then the big three for less $$$, I know that's why I bought mine.
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
2006 Lufkin 45ft. 40 Ton T/A Flatbed Trailer (A59230)
2006 Lufkin 45ft...
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
2019 CATERPILLAR 289D SKID STEER (A60429)
2019 CATERPILLAR...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
