bush hog squaler sq480
   / bush hog squaler sq480 #1
grizz43
hello i have bush hog squaler sq480 4 foot trying to keep it matntained i have a box deal i think it is called a gear box how much oil and what kind of oil do i put in it it has a threaded plug on top and a drain plug on the side by the bottom i put i hose to measure it it is about 1/2 about the plug on side is that enough or do i fill it up more please help.
   / bush hog squaler sq480 #2
Usually top hole is breather, side hole is fill hole, pour in till it starts to run out .if my memory is correct 90 wt gear oil.
DevilDog
   / bush hog squaler sq480 #3
DevilDog
That's right. From the Bush Hog online manual:
"Gearbox - Check oil level by removing oil level
check plug on right side of gearbox. Add EP80W-90
gear oil if necessary to bring oil level to check plug​
hole."
   / bush hog squaler sq480 #4
why do they not have a drain plug?
   / bush hog squaler sq480 #5
I can't say for sure, but I'd guess it's because the output shaft is a verticle shaft; i.e., straight down. Where could you put a drain plug in the gear housing? I sure don't know of any place it could be located that would allow you to drain it.
   / bush hog squaler sq480 #6
Some do. My Caroni 6' has one but my Ford 5' does not. I have only changed it once in the Ford and i just tip it up on its side and lean it against a tree with the FEL to service.
Chris
   / bush hog squaler sq480 #7
75w90, 80w90 or 85w140 would / should all be suitable oils...
soundguy
UNUSED CHERY INDUSTRIAL 10' - 18 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
MONOSEM NG-3 LOT NUMBER 273 (A53084)
MONOSEM NG-3 LOT...
1996 UTILITY 101" X 52' T/A FLATBED TRAILER (A51247)
1996 UTILITY 101"...
Adams Tender / Magnolia Trailer (A53472)
Adams Tender /...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
