Rotary Cutter Bush Hog SQ48
   / Bush Hog SQ48 #1
Hunterdog
Kubota B7510
I recently purchased a Bush Hog SQ48. Based on the serial number it is one of the early iterations. The stump jumper is completely busted and I am having no luck finding one. The original Bush Hog part number is 63826 (formed pan).
I have been able to find the following:
Diameter - 24.7"
Center Hole - 1.568"
Distance between blade bolt hole centers - 15.49"
Blade bolt hole diameter - .937"
The center hole has no splines and it appears that the pan is attached to the blade carrier bar via the blade bolts.
I would greatly appreciate any ideas/suggestions for finding one of these, or a suitable replacement.
   / Bush Hog SQ48
Thanks I'm trying to reach them now. Will let you know what I find out.
Toro Workman Utility Cart (A51694)
Toro Workman...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2021 HYUN Elantra (A50324)
2021 HYUN Elantra...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
