Rotary Cutter Bush hog slip clutch adjustment
   / Bush hog slip clutch adjustment #1
kenacp
Bronze Member
New Orleans and Liberty Miss
John Dere 770
I have a 4' Clipper 400 bush hog with a protective slip clutch on the pto shaft. Can anyone tell me the proper way to adjust the tension on the disc plate? This has been sitting up a while, and just want to make sure it will function properly. Thanks,Kenny
   / Bush hog slip clutch adjustment #2
Use the search function for "pto clutch" or "slip clutch". Many to choose from like this one: http://www.tractorbynet.com/forums/attachments/119531-how-properly-adjust-king-kutter.html
Basically loosen the ring of bolts until it slips when mowing, then tighten each bolt one turn at a time until it stops slipping. Mow -check temp -adjust, mow, check temp adjust, etc. It will get warm if it's slipping. Many intentionally slip the clutch at the beginning of the season to dislodge rust, etc. then retighten. Often just count the turns loosened & retighten the same number of turns. MikeD74T
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55314)
2025 Mahindra 6075...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2022 CASE CX57C EXCAVATOR (A52707)
2022 CASE CX57C...
199049 (A51243)
199049 (A51243)
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
