Bush hog size
   / Bush hog size #1
mbandrlb
Hoschton,Ga.
.Mitsubishi MTE1800FD
Hi all,
What is the max size bush hog I would be able to use with a 18 HP tractor? I have looked at a 4' and 5'.
Thanks,
Mike
   / Bush hog size #2
The common rule around here is 5HP (at the PTO) per foot of cutter.
That said, if your in light grass you have a little more of a margin. Without seeing your environment, it would default to the 4ft unit and it would be pushing it.
   / Bush hog size #3
Um, your profile says Deutz D4006. That's a 35hp tractor
//greg//
   / Bush hog size #4
Agree, they probably don't make less than 4 footers. I pull a 4 footer with my 27hp tractor and it gets bogged down in the thick stuff.
   / Bush hog size #5
We have an '86 Deere 750 with a 20 hp yanmar diesel. It is rated 18hp at the pto. We use a 4ft Bush Hog Squealer rotary cutter. In 1ft tall weeds, ground speed is limited to2.6 mph in 4th gear. In 5 ft tall brush we have to go down to 3rd gear at 1.6 mph or even 2nd at 1.1 mph in really thick stuff. There is no way I would want a bigger hog on this size tractor.
In addition to power is the issue of weight. A quality 5ft hog weighs a good bit more than a 4ft one. It takes 5 suitcase weights on the front of the tractor to make lifting the 4 ft hog comfortable. If you have a loader, this isn't really a concern.
Opinions will differ though. I know a gentleman that used a 5 ft hog behind his Deere 650 and said it did fine. I didn't inquire further, but I can only assume he was using a very lightly built hog and cutting his land in frequent intervals.
   / Bush hog size #6
Bush Hog makes a 42" cutter in the Squealer line.
   / Bush hog size
//greg//
I need to change that.I just picked up a 18 HP Mitsubishi.4wd and FEL.
Mike
   / Bush hog size #8
Ok, the loader will definitely be of assistance in offsetting the weight of the mower. A lot of Asian tractors are rated by PTO hp. If that's the case with yours, you'll handle a 4' RC just fine - if you limit your mowing to light and medium duty stuff. Yes, a 42" might be better, but - because so few are made - they're typically more expensive per cutting inch. Plus, it might be too narrow for your tractor width. You want a mower that is at least as wide as the tractor, ideally a few inches wider to aid in mowing edges.
//greg//
   / Bush hog size #9
I used a 4' Bush Hog Squealer behind my B7100 Kubota and a 5' Howse 500 behind my B2710 Kubota. They were the right size for me and my uses; yours may vary depending on what you're trying to cut.
   / Bush hog size #10
Straight out of my Bush Hog Squealer Series Operator's Manual:
SQ420 10-25 Recommended Tractor HP
SQ480 15-30
SQ600 25-40
SQ720 30-45
For the record, I pull a SQ480 behind my NH TC-40 with obvious ease-the SQ480 is left over from my first tractor, a Ford 8N. I may some day trade it for a larger cutter.
2004 JOHN DEERE 310SG EXTENDAHOE BACKHOE (A53843)
2004 JOHN DEERE...
500 BBL FRAC TANK (A53843)
500 BBL FRAC TANK...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
