handirifle
Veteran Member
So my neighbor approached me a week or so ago. Says he has this 4' bush hog that he has not used in years, and wonders if I want it, duh, of course.
Everything is in great shape, except, the drive shaft slip section is frozen. He told me it was but said with heat and a hammer it has always come loose before. Well I have tried heat, before and after penetrating oil. No luck. I tried "coaxing" it with a hammer and no luck.
I have sprayed the penetrating oil as much as I can and now this is two unsuccessful days at freeing it up, so here come my questions.
My first bush hog of any brand/type. Not a complicated machine, but looking at it, in order to remove the shaft completely it looks like I need to remove the snap ring on the gearbox yoke, and what I THINK is the shear pin about 3/8 or 7/16" dia. Does this just hammer out, and does it matter which side it goes out? Is it reusable if I do, or do I need a new one.
I am hoping I can take the shaft to SOMEONE that can force it apart. Once that is done I will clean both pieces and make sure it is well greased.
Suggestions? Anything else I should try? The PTO end is free, as I have not been able to compress the shaft to even try the darn thing out. Everything turns freely, its just the slip shaft, doesn't slip.
