Bush hog sapling size
   / Bush hog sapling size #1
VroomVroom
Platinum Member
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
I say bush hog, but I really mean any rotary mower. I'd like to clear alder along side the dirt roadside as they are growing in quite fast. The alder grow small here, but some may be nearing 2 inches in diameter, where most would be an inch. Can a rotary mower handle this or is it mostly for longer grass and such. I asked a dealer about a rotary mower for the mahindra 2816 hst I have and he said a 5 foot would require 30 pto hp minimum and that it wouldn't handle any saplings and wouldn't be covered under warranty. I thought thats what the bush hogs and similar mowers were for, was for small bushels and tiny saplings that would be painstaking to remove with the chainsaw. Can anyone clear me up on this?
   / Bush hog sapling size #2
Bush Hog brand HD rotary cutter rates theirs at 3 1/2 inch's.. some don't rate them. But I dont think you have even half enough power to cut 3 1/2 inch saplings. But you said yours might go 2 inches. That is still more than I like to cut with my King Kutter Light duty cutter. But my advise would be to get the most heavy duty one you can afford, and think about going down to a 4 foot. Lets see what some others have to say, that have more experience cutting saplings. By the way it makes a heck of a racket! But in general terms, yep they will cut brush!. A a properly adjust slip clutch on the cutter would probably be a good idea. I believe the more HD ones will come with this.
James K0UA
   / Bush hog sapling size #3
My Ford 1710 is about the same size as your Mahindra. I pull a 5' Bush Hog Squealer and cut a lot of saplings. I have gone as big as 2.5" and not had any problems but I do take it slow. I think the tractor has plenty of power for the mower but I wish it had live PTO. The Bush Hod is also a load for the 3 pt - it handles it but you can certainly tell that it is back there.
I wouldn't hesitate a bit on a 5' but I would have a good slip clutch or at least a shear pin to protect your tractor.
PS - For saplings one inch and under I use my sickle bar mower. Basically I use my sickle bar wherever I can and my Bush Hog for the ugly stuff.
   / Bush hog sapling size #4
I had alot of experience mowing CRP ground last season. 115 acres with a small sampling of different trees that had sown themselves. Oak , Ash ,and Cedar were all present. Get on them now before they get any bigger. The bush hogs all have different size gear boxes and of course you would like a heavy one. My limiting factor was the PTO shafts. Big stuff tears them up. Twists the tubes right up. Went to a larger horse power tractor and ruined euipment faster. There is a time and place for a chainsaw. A clutch on the bush hog would have quickly paid for itself. Backing into the brush is sometimes wise. All tractors used had a front loader and an idiot running them. [me].
   / Bush hog sapling size #5
How thick are these saplings? It makes a difference if the blades can stay extended and up to speed.
I'm normally exceptionally easy on equipment, with the HST i'd back into the brush alarmingly slow, theres no time limit. I just wanted to know if it would handle the smaller brush. I have to do about 10000 feet, one pass. Most would be 3/4 inche, Most of the bigger stuff of 2 inches would have been cut already with the chainsaw, though there might be the occasional one that size. The old stumps of that stuff though may be there up to 6 inches in height. The dealer recommended 4 foot width.
the impression I got from the dealer was that it wouldn't cut any saplings.
   / Bush hog sapling size #8
Is this the tractor dealer?? Or implement dealer??
Either way, they are an idiot. Unless of course they/you are talking about a finish mower.
And a 5' cutter certainly doesnt need a "minimum" of 30HP. My kub is 29 @ the PTO and I run a 6' no problems.
Those two things there tell me to look for another dealer ASAP.
As to the sapplings, I wouldnt want to try the 2" stuff very often with a light duty cutter. For what you describe, it sounds like you need a medium duty cutter. On the plus side, Alder is softer wood and cuts easy with a cutter.
Personally, I'd be checking craigslist for a $150-$200 old cutter that still works. Get this job done, and then get a nice shiny new one for the upkeep if you so choose
Edit: I forgot to ask, What brands of cutters does this dealer sell??
   / Bush hog sapling size #9
I cut saplings up to 1-1/4" with 48" King Kutter Standard Duty Rotary Cutter behind my 25-hp/PTO tractor regularly, but I have to go slow where they are thick, so RC will not bog down.
Your Mahindra, when new, had 21-hp/PTO. You should be fine with small saplings, if you go slow.
If you run PTO powered implements too heavy for your tractor it strains the tractor leading to increased repair. The tractor has to provide power to move itself, move the implement, and spin the blade; TRIPLE LOAD.
I think your dealer advised correctly that a 48" RC is more appropriate for 18-21-hp/PTO horsepower of your tractor today then 60" RC.
From your opening post, it seems a Rotary Cutter is what you need, as saplings are your main concern. However, you might research Flail Mowers too.
You will get replies better tailored to your tractor if you enter tractor/HP/weight in your heading.
   / Bush hog sapling size #10
The heavier duty cutters will handle up to 3.5" (Bush Hog brand specs). But there will be a lot of stress put on your tractor. Remember, the weakest link will fail. Up the cutter specs and your tractor driveline and engine becomes the weakest link. YMMV but I'd rather have the cutter fail!
New/Unused 20ft x 40ft Container Shelter (A44391)
New/Unused 20ft x...
PREVIEW DATES AND TIMES (A44391)
PREVIEW DATES AND...
2008 KALYN BLENDER (A45333)
2008 KALYN BLENDER...
D5H LGP open rops (A42203)
D5H LGP open rops...
2016 Ford Explorer AWD SUV (A44572)
2016 Ford Explorer...
2011 FREIGHTLINER M2 (A45046)
2011 FREIGHTLINER...
