Bush Hog/rough cutter recommendations?
   / Bush Hog/rough cutter recommendations? #1
Skyco
Elite Member
SC/NC
I have no real need for a Bush Hog/rough cutter type rear attachment but my 77 yr old father mentioned he might spring for one to clean up some property he owns :)
I figure a small one, no more than 48" or even a 40" might be decent on the BX24. Anyone care to share experiences/prices/sources etc?
TIA!
   / Bush Hog/rough cutter recommendations? #2
King Kutter makes some rear implements designed specifically for the BX sized tractor. They're available around our area at the Tracor Supply Co.(TSC) stores. Power wise you'll have no trouble with a 4ft. Weight and hitch heighth will be your biggest factors.
   / Bush Hog/rough cutter recommendations? #3
Skyco:
I bought an el-cheapo at Tractor Supply, it was the least expensive that I could find. It is a "FarmForce", 48", $599. I only cut about 2 acres once a year.
I use it on my BX23, it does a great job. No problem with the lift height or weight. I had to shorten the shaft a lot.
Here are a couple observations. I had ZERO experience with one of these before.
1. I hated driving through really tall stuff with my BX23, but it appears that I had no issues with it. I went straight over trees up to about 8' tall, maybe 2 inch in diameter. I pushed them over with the bucket as I went. NO PROBLEM!
2. I was worried about flats. That was no problem either. The blades pulverized the stumps, driving over them was no issue.
3. ROCKS! I hit lots of rocks, never even knew they were there. I threw a couple bowling ball sized rocks about 30' from the machine. Be careful! There appeared to be no damage from that, the cutter kind of rides up and over stuff like that, the blades never stalled. I did notice that it would come out of balance, I had to shut it down and re-start it. The blades are loose, I think that by re-starting it straightens them out.
Have fun, you get a lot of stuff that looked impossible to cut done fast.
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
Trailer Axle (A50860)
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2015 Craftsman T1800 42in Riding Mower (A48082)
2015 Craftsman...
71066 (A49346)
71066 (A49346)
