Bush Hog roto tiller shaft repair/replace?
   / Bush Hog roto tiller shaft repair/replace? #1
knibloe
Upstate, NY
kioti ck30
I broke my roto tiller this spring and need to get it fixed. The shaft that holds the tines broke in half. Looks like a new one is $1200. My questions are:
  • Someone told me I could take it off and get it welded back together. To me it seems like it wouldn't hold.
  • Does anyone know where I might find a used one?
   / Bush Hog roto tiller shaft repair/replace? #2
A good welder should be able to weld it back as strong as it was. Probably need to ask around locally to find a good welder.
My dealer recommended the shop they send their welding work to, and they did some amazing things for pretty reasonable prices when I bought an excavator that was far more abused than it appeared just used.
   / Bush Hog roto tiller shaft repair/replace? #3
Any place that does drive shafts would probably work. They can even balance it.
   / Bush Hog roto tiller shaft repair/replace? #4
Might be better to just make a new one. I don't see any pictures so it's hard to tell. Is this the garden type tiller or 3PH tiller? How wide? How is it driven?
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
Electric Concrete Mixer (A51573)
Electric Concrete...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
