Bush Hog Rotary Cutter
   / Bush Hog Rotary Cutter #1
Blackhawkranch
New Holland 555E
I need the left side gear box output shaft for a Bush Hog Model 160/1600, Serial # 601943. Bush Hog will only sell as a shaft kit for $480.00! This is an old cutter and I don't want to put that much for one part. Does anyone know of any after market parts that may be available or a dealer that may have some new/old stock. I purchased one shaft only many years ago from a dealer.
I have tried to find a junked cutter but have not found one. The left side and right side should have the same shaft.
   / Bush Hog Rotary Cutter #2
See if you get a "will fit" box from Agri-supply. May have redrill a couple of mounting holes, but should be do-able. bjr
   / Bush Hog Rotary Cutter #3
If you can get the part number, it looks like Messick's and a few other places can probably get you the correct replacement for a lot less than $480.
I actually contacted Messick's. All they have is the Shaft kit for $480.00.
Thanks. Ken
Thanks. They do have a 75 HP gear box that may work. I would really like to find a shaft for the original box. The nearest Agi store is 3 plus hours from me but I will try to go & see if it will work. I don't want to order online unless I know it will fit my machine. Thanks again. Ken
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
SHOULE LN-16 LOT NUMBER 132 (A53084)
SHOULE LN-16 LOT...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
