bush hog recommendation
   / bush hog recommendation #1
trc313
kubota mx4800
new to the forum!!
I have a kubota MX4800 and need a bush hog to do about 8 acres. Its fairly hilly with some exposed rock here and there. What size would you recommend. I borrowed a 4 foot from a friend and it took way longer than what I wanted it to. I want something that will last and a good warranty. Thanks in advanced
   / bush hog recommendation #2
I have a six ft.Landpride on my L4240 and it's a good fit;also have a 5ft.Bush-Hog branded on our 30 H.P. tractor and it has a ton of hours with no problems.The six footer would be a good fit for yours.
   / bush hog recommendation #3
6 or 7 footer. 7 foot single spindle will be a unwieldy beast when turning. 7 foot dual spindle would be fine. Land Pride RCD1884.
   / bush hog recommendation #4
I’d go with the 6ft. A 7 is going to be a tiny bit much if you have to delay cutting for whatever reason and the grass gets thick, especially on that hilly ground.
   / bush hog recommendation #5
I have a LandPride 6 footer on my MX5200 and it works great. I wouldn't want another foot
Andy
   / bush hog recommendation #6
With your roughly 40HP PTO rating, you go up to an 8 foot rotary cutter. However, at this size, you may find your tractor maxed out with tall grass on your hills.
The issue comes that a single spindle 7 or 8 foot unit gets to be beast. While dual spindles on these takes a bit more HP to run effectively. If you are able yo stay on top if the cutting, you should be able to use these, if you only plan to cut a couple of times a year, you will be better served with a 6 foot cutter.
Regardless of width, get a cutter that is build heavy and able to cut a bigger diameter material than you plan to cut. If you plan to cut up to 1” stuff, get a cutter rated to cut 2” stuff. You will get much better service from the cutter long term.
   / bush hog recommendation #7
We have a Woods BB720x (6ft) on our MX5800 tractor. It does a great job on the brush and saplings. It has a 3" cutting capacity and is pretty stout at ~1200 lbs. We paid a little extra for the chain guards.
   / bush hog recommendation #9
Six foot would be good fit. Seven ft single would be a beast. Medium duty should be sufficient unless its going to take a beating. I’d stay away from those light duty models that many offer including major brands like Bush Hog.
   / bush hog recommendation #10
If you have HST, 8' twin. Only downside is they are about twice the cost of a single spindle 6' mower. And for only 8 acres.....may not be worth it.
A single 6 should do that mowing in about 3 hours, a twin 8 might cut it down to 2. If that 8 acres is all you got....my money would tell me to stick with the 6' just due to cost
Backhoe Attachment (A50322)
Backhoe Attachment...
UNUSED JCT SKID STEER QUICK ATTACH SNOW PUSHER (A51244)
UNUSED JCT SKID...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
1997 Semi Dump Trailer (A50514)
1997 Semi Dump...
(4) 10' High Pole Swinging Gates (A50515)
(4) 10' High Pole...
