Bush Hog FH-188 Flail Mower 88"
   / Bush Hog FH-188 Flail Mower 88" #1
Texasgreen
Mont Belvieu, TX
06 Montana 4940C/R4/FEL arched boom.
I'm selling my flail mower. If a beautiful, smooth, contoured appearance is important, you want to mow with a flail mower. Flail mowers are ideal for contractors, government entities, lawn care professionals, contractors, property owners and homeowners with larger yards.
I have taken good care of this mower and I keep it inside when its not in use. I have fine cut knives on it at this time for a smooth finish. I also have a new set of fine cut knives and ruff cut knives to go along with it.
You can run this mower with a PTO HP as little as 25HP, but a 30+ PTO would be best and much easier on your tractor. You can come over to my place and try it out with my tractor or bring your tractor to see if it will run this mower and see how well it cuts. Asking $1,400 for it. Call or text Trent @ 281-785-6935
I'm located in Mont Belvieu, TX 77523, just 30 miles East of Houston, TX.
   / Bush Hog FH-188 Flail Mower 88" #2
I'd buy it but you live a bit too far away for me to have time to go get it.
   / Bush Hog FH-188 Flail Mower 88" #3
Looks like a nice mower:)
I have not heard good things about flails cutting this wiry stuff we can grass in our part of TX. How has this one worked for you in your part?
I have mostly used this flail for mowing areas where the grass was more of a lawn type. In lower grass, 14" or less, it cuts very well. I have run it through some taller grass in a paster with the fine cut knives where the grass was very tall, 3'+ and thick and it did okay, but no where close to cutting like a rotary brush hog would do.
When I bought this flail, it had the ruff cut Y type knives on it and it would mow the heavy thick grass much better then it will with the T style fine cut knives I have on it now. If you lined this flail up next to a rotary type brush hog mower and ran them at the same time in a heavy grassed paster, the flail will fall behind.
This flail mower with sharp fine cut knives has cut much better then any finish mower I have owned or mowed with.
   / Bush Hog FH-188 Flail Mower 88" #5
I have a big finish flail, too. They do a great job of chopping up the long clippings and leaving a finish look.
I'm not using it quite as much as I'd like, so I may be selling mine, too. I really need a sickle or disc mower. I'm in Phila, PA suburbs.
Adams 6Ton Hydraulic Lime Spreader (A53473)
Adams 6Ton...
2015 3500 HD Chevrolet Ambulance (A52377)
2015 3500 HD...
2015 TEXAS PRIDE  GOOSENECK (A53843)
2015 TEXAS PRIDE...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
