Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,641
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Found a way to get the PTO shaft on the PTO spline when attaching the Bush Hog.
MACHINE OFF! I pull back the collar with one hand, after eyeballing the PTO female end of the shaft at the U-joint to align the splines of both ends. Using a 2' or so long fulcrum of choice, (long, relatively thin shaft screwdriver will do), I place the screwdriver through the yoke of the U-joint and slide it down to where I can use it to force the entire PTO shaft forward toward the tractor rear end. On my tractor this is where the drawbar plate is located. This allows me to keep the release collar pulled back, while using the screwdriver to push forward. A pull me push you kind of beast it is! Otherwise I find it near impossible to pull and hold the collar back while trying to move the shaft forward onto the PTO spline, especially with the PTO shield in the way of the two opposite motions.
REMOVE screwdriver, lower safety shield over PTO shaft and spline. Recheck all connections, pins, etc.
Enjoy your hoggin':thumbsup:
Hope this idea is useful to some- I know it worked like jelly for me today!
