Rotary Cutter Bush hog blades
   / Bush hog blades #1
cadillac
Sanford, NC
Kioti CK2510HST
When I first got my Howse 350 bush hog I ended up hitting a piece of wood and the blades got crossed. I removed the big pan assembly and the blades to free them from each other.
When I put them back on, one was tight and the other was loose (pivoted freely). Being a novice, I shimmed the loose one to match the tight one. After reading some it seems they should both be loose. Is that correct?
   / Bush hog blades #2
Both blades should swing freely from their pivot point.
Mike
   / Bush hog blades
that being the case, I assume I should only tighten the nuts until the blade just moves then install the cotter pin.
   / Bush hog blades #4
On mine you can't tighten the nut too tight - there is an unthreaded section of the bolt on which the blade swings. I probably have 1/8'' "wiggle room" with the nut just as tight as possible. So, to answer your question - tighten enough to allow the blade fairly free motion. You may want to peek at your owners' manual to see what they have to say on the subject.
Mike
   / Bush hog blades #5
I agree.. should be a shouldered bolt that you can torque down and leave the blades free to pivot.
soundguy
   / Bush hog blades #6
Are the blades bent? I bent the blades on a Woods Dixiecutter upwards a bit. They'd swing a little bit but wouldn't rotate if I hit something big and would get stuck backwards towards the center of the mower. Vibrated like a bugger so there was no missing when it happened. I could use them for a while with care but ended up replacing them. That's not your trouble, is it? How about junk wedged heavily in where they pivot so that one's bound up a bit?
   / Bush hog blades #7
The ability of the blades to touch is one reason I don't like cheap cutters.
Both should swing freely. It allows them to bounce back from hitting an object.
jb
   / Bush hog blades #8
...I ended up hitting a piece of wood and the blades got crossed.
Happens all the time when mowing in the woods. I just lift up the mower and beat them apart with a hammer that I carry in my tool box. Had it happen on Sunday. Once they are free of each other, I start it up again and give it a second or two of low RPM's to sort of balance itself out again, then start mowing.
Eddie
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
1980 Gleaner F2 with heads (A57024)
1980 Gleaner F2...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55314)
2023 Kubota...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
