Rotary Cutter Bush Hog BH6 vs. Rhino RH6
   / Bush Hog BH6 vs. Rhino RH6 #1
gckshea
Bronze Member
SE Tennessee
2018 LS XR4140
I am searching for a gearbox output shaft seal for my 2018 Bush Hog BH6 Rotary Cutter. It appears the Rhino RH6 (don't know what years this one was made) keeps coming up as having the same gearbox/part number: 00786214. Then I look at photos of each cutter and they look identical. Was Bush Hog making them for Rhino in these years, or visa versa? Could I go with either brand's parts, and assume the part number is actual one in the same? Any suggestions and info?
   / Bush Hog BH6 vs. Rhino RH6 #2
They could both purchase the gearbox from the same manufacturer - I doubt either company is the source for the gearbox. The seal itself is probably a standard off the shelf item available from any bearing supplier.
   / Bush Hog BH6 vs. Rhino RH6 #3
I went by dimensions to replace seals on a Woods gear box, rather than go to Woods dealer.
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2022 ALLIANCE NORTH AMERICA, INC SDG45 GENERATOR (A52472)
2022 ALLIANCE...
