Bush Hog ATH600 Gearbox Leak
   / Bush Hog ATH600 Gearbox Leak #1
MattB2710
Was out in my shed this morning, and found the gearbox on my Bush Hog ATH600 Finishing Mower has been leaking oil.
The mower was purchased in 1999 and has less than 100 hours of use. Shed is unheated. What attacted me to the leak was a heavy grease/oil smell. Oil, light brown in color, is leaking on the upper deck of the mower and is running off the back of the deck, there is no oil under the mower deck. Warranty was only 1 year. Have called Bush Hog for parts diagram. I think an upper seal maybe leaking.
Anyone else have similar problems?
Any ideas on repair suggestions?
Thanks,
MattC
   / Bush Hog ATH600 Gearbox Leak #2
I don't know if finish mower gear box is the same but on a field mower gear box that leaks oil the fix is to check bearing preload and replace seal-
When the shaft has to much side-side play it takes out the seal which causes gear box to leak oil-- and if not caught in time blows up gearbox
   / Bush Hog ATH600 Gearbox Leak #3
Mine leaked around the coarse threads of the fill plug, but it occured only when the transmssion was spinning. I fixed it with teflon tapes and an extra turn. If yours did this just sitting there in a cold shed, you might have water in the transmission. Gear oil floats, and water expands when it turns to ice. The expansion could have forced oil past the fill plug threads, then ran down to pool at the base of the transmission.
//greg//
   / Bush Hog ATH600 Gearbox Leak #4
Matt, where is the leak? Input shaft, vent, filler plug?
Bird,
It appears to have leaked out the output shaft, or the bottom of the gearbox. I opened up the filler/inspection cap and the gearbox case appears to be empty/dry.
What a stinky mess to clean up.
   / Bush Hog ATH600 Gearbox Leak #6
I'm only guessing, but sounds to me like L3710GV has the right answer.
Anyone have and idea on repair costs???
Thanks,
Matt
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
