Rotary Cutter Bush Hog 305 question
   / Bush Hog 305 question #1
rossco
Bronze Member
South Texas
Kubota BX 2200 / John Deere 5083E
I just picked up an old Bush Hog 305 that needs some deck replacement. It appears that the gearbox is supported by the heavy metal structure above the deck, so that is a real good thing, but the deck below the gearbox is rusty and needs replaced. I was looking at the parts diagram and need to know what the buck plate assembly is at the deck where the gearbox shaft goes through the deck. What is it's function? It appears to be a larger bolt of some sort, but I can't figure out what it does. Just trying to see what I will be getting into replacing this portion of metal. The heavy duty structure above the deck is great, but looks like it also led to the bad rust because it traps grass and water if left outside. If it wasn't for this structure though, it wouldn't be worth replacing the deck. Anybody who is familar with this, please chime in. Thanks
Parker 4000 Gravity Wagon (A50774)
Parker 4000...
Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
Kubota SVL95-2S...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
2001 Dodge Ram Wagon Passenger Van (A51692)
2001 Dodge Ram...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
