Bush Hog 296 question
   / Bush Hog 296 question #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
Picked up my new BH 296 to go with new JD5065e today. The dealer loaded it on my trailer by gentle wrapping a chain around the power head so as not to impart any load into the PTO receiver part of the head. He then lifted it up with a Ford tractor FEL and gently placed it on my trailer . My question is can the head structure and the 6 bolts that penetrate the deck take that 1100 load without damaging it? It looks fine and the under-deck of that 296 is very stout. I would have thought it wiser to lift at the designed lift points where 3 pt attaches and/or tail wheel. Any advice?
   / Bush Hog 296 question #2
No worries. Deck is plenty stiff it ain't hurt and those bolts and gearbox are plenty strong.
   / Bush Hog 296 question #3
If you use a 296 for what its worth those bolts and gearbox will go through a lot more stress than that. I have an older 286 and the guy who had it before me beat the 1/2"x4" blades off it trying to clear an overgrown field full of rocks. I gave him $300 for it, put two new blades on and its been going strong for three years now. You've got nothing to worry about there but if you ever want to lift it again I usually run a chain from the adjustment on the tailwheel up to the toplink. The balancing point is just in front of the gearbox. Good luck and happy hogging!
   / Bush Hog 296 question #4
I typically put my bucket lip up to the lower lift arm pins and chain around where top link mounts since this area was designed for lifting at this location.
   / Bush Hog 296 question #5
They used a forklift to load mine. Slid the forks under the deck, above the blades. I did the same to unload, but my forks were too short so I had to also run a chain from the from back frame to the top link mount.
I would say no worries, but rather they used a sling than a chain.
   / Bush Hog 296 question #6
I have a 286 (actually just serviced it yesterday) and the gearbox/bolt ring would hold many tons versus the 1000lbs of mower. These models are built like tanks. Other than paint marks, I would not worry one bit.
   / Bush Hog 296 question #7
Just curious but what does a new 296 6 foot hog cost new?
   / Bush Hog 296 question #8
You bought a really nice cutter and a good match for your horsepower. Are you planning on mowing down small forests? I have a similar cutter that is built extremely close in specs and it is absolutely built like a tank. There really isn't much you can do to hurt a heavy duty rotary cutter like yours. (even though BH calls them medium duty, they're more heavy duty that even some so called "extreme duty" cutters from other manufacturers.
We'll wait for pics. :D
My gear box does not have a dipstick. It has a fill plug on top with what looks like a breather cap (?) and also an Allen plug on side for level check (fill until runs out hole). My shaft has shields on each end with chain stays to keep plastic tube and shields from rotating. There is a grease fitting on each shield with no dust seal. Do you put grease in shield fitting? Another fella told me to not use chain stays and let shields rotate? The dealer only pointed out the u-joint grease fittings (2) along with 2 tail wheel fittings. Is it dumb to let shields rotate or should they be stayed and ride on grease layer. I would think without a bearing the plastic would glaze over even if greased. Like I said the grease fitting on shield has no dust ball like std grease fittings. Seems intent is to just get grease in there for plastic to ride on shaft
I paid 2795 including chains front and rear. It looks very stout.
2006 BIG TEX 16 T/A TRASH TRAILER (A53843)
2006 BIG TEX 16...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
