burying invisible fence wire
   / burying invisible fence wire #1
juddspaintballs
Berkeley Springs, WV
Kubota MX5100 HST
Is there a handy attachment for burying the invisible fence style wire? When I installed it at my other house (1/2 acre yard), I borrowed my dad's walk behind hydrostatic stump grinder and ground a mini trench about 2" deep all the way around the yard. It made a wider trench than necessary, but worked. This new house, I'm fencing in about 4 acres for the dogs and I can't go borrow the stump grinder now without spending 3 hours on the road. Is there a commercially available attachment for burying this wire? If not, I was thinking of welding up a 3 pt attachment that basically is a plate of steel about 1/2" thick and 3" wide with a sharpened point that sticks down into the ground and can knife a 1/2" wide cut through the grass and dirt a couple inches deep so I can put the wire in that mini trench. Any input appreciated.
   / burying invisible fence wire #2
A middle buster might do it. Keep the 3pth on the high side so you don't go too deep. If you were to rig a hunk of pipe onto the back side of the buster and a axle for the spool of wire, you could do the whole thing in one go.
   / burying invisible fence wire #3
a sub-soiler would be a good choice. they make them with a tubing feeder(extra money) that cuts a 1" trench. If this is a one time use I wouldn't add the pipe feeder. you could just feed the wire as you go.they are about $150. db_file_img_318_800x450.jpg
   / burying invisible fence wire #5
I have installed invisible fence wire and I have used the Rip and Dig but not for the wire. I didnt have the rip and dig when I put the wire in.
It might work using the ripper function. I havent tried that feature yet.
For me it would depend on whats available to you. I think your idea about making something is good. The goal would be to avoid tearing up too much. I think any one of the tools mentioned would do it, but I dont know which would be best.
The subsoiler looks like the ticket. It wouldn't be hard to modify it for a spool of wire to feed either. Northern Tool has a subsoiler for $120 for a Cat 1 3 point and I could hardly make one cheaper than that in time and materials.
   / burying invisible fence wire #7
Yah, I agree.
   / burying invisible fence wire #9
   / burying invisible fence wire #10
I think using an edger attachment is the most common suggestion.
Another option is a cheap chainsaw with junk bar and chain you can toss when done.
300 Gallon Water Tank (A42742)
300 Gallon Water...
2008 Ford F-450 Ext. Cab Reading Service Truck (A42742)
2008 Ford F-450...
ClubCar Electric Golf Cart (A42744)
ClubCar Electric...
2002 Chevrolet Silverado 4x4 Ext. Cab Pickup Truck (A42744)
2002 Chevrolet...
2009 PETERBILT 367 TWIN PUMP CEMENT TRUCK (A45333)
2009 PETERBILT 367...
INOP/NON-RUNNING 2006 Isuzu NQR Truck, VIN # JALE5B16967300138 (A44391)
INOP/NON-RUNNING...
