Burnt valve?
   / Burnt valve? #1
scesnick
Veteran Member
Garrett County Md. ( Western Md.)
Kubota MX5100
I have a 1977 case 480 Construction King and I recently went out to plow my road. I finally got it started, it was very cold outside, and it started popping. I then ran it again this week and the popping all of the sudden got extremely loud ! It still seems to run fine, although i didn't run it long like this.
I'm not all that knowledgeable with diesel motors. Hopefully it is not what I think it is.
If it is burnt valve what is the ball park figure this is gonna cost me??? thanks... /forums/images/graemlins/confused.gif
   / Burnt valve? #2
If it is accompanied with rough idle, I normally loosen inj lines one at a time to find which cylinder doesn't affect performance. Once that is found, try swapping inj with another cyl and repeat test If problem moves to another cyl, it's inj, If it remains in same cyl, I'd suspect valve. Still I would look closely at valve train of affected cyl and check lash before taking off head. There have been a bunch of heads removed for no reason.
   / Burnt valve?
MMM,
It seems to idle fine. It just pops very loud. It was pretty loud and then all of the sudden the popping got extremeley loud.
It does not seem to effect the performance of the hoe much if any. Hopefully it is the injectors but how can i check if the idle is normal?
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A53426)
2012 VOLVO VNL...
2017 International DuraStar 4300 2,500 Gallon Water Truck (A51692)
2017 International...
