Burnt Clutch on a 107d
   / Burnt Clutch on a 107d #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
Yesterday I can distracted, and left my tractor in gear for about 3 minutes, the tractor started moving, and you smelled the clutch burning. Is this the end for this clutch?
   / Burnt Clutch on a 107d #2
Maybe.
I burned mine up when I first got it because the PO didn't have it adjusted correctly and it was slipping, especially when I engaged the flail mower. It got worse and worse until the tractor wouldn't move much less turn over the flail mower. The latter puts a big load on the clutch.
If you determine you need a new clutch you can just send the clutch off to Earth Tools and they will rebuild it for about $100 (IIRC) - that is what I did. Pretty easy to take the tractor apart and take the clutch out.
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
2000 Sterling L9513 Winch Truck (A53472)
2000 Sterling...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
