Burning Wood Chips/Scrap
   / Burning Wood Chips/Scrap #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
I've searched the web but I'm real interested as to what real life experiences you folks have encountered regarding burning wood chips. We do not burn wood as our primary source of heat, just use it when we get the -25/-30C temperatures as well as any power outages. It would be a great option to be able to burn the chips (as well as justifying a PTO Chipper) because I try to just cut the dead wood/branches on my property but I'm curious about how you get them to burn properly/completely in a conventional wood stove in the basement. Any words of wisdom/experience would be appreciated. Up to this point, I've just had a big brush pile a couple times a year & burn the pile, but it seems a shame when I could use this scrap as a heat source in the winter. What's your real life experiences ??
Eric
   / Burning Wood Chips/Scrap #2
I have an outside wood fired boiler and have burn chips with good results. I don't know how well they would burn in an inside stove. Some of my chips are dry and some are not. I have filled a 50Lb paper bag and thrown the whole thing in. In 20 drg weather it last for about 8 hours.
   / Burning Wood Chips/Scrap #3
Depends on if they are dry chips (dried after chipping) or green chips (burned right away). If chips are left in a pile, they will heat up from bacterial action, and begin to decay. But chips in a pile won't dry out.
Wood, in chip form or solid, that is not dry, will consume much of its BTU energy potential just to convert the moisture to steam, thus being less effiecient and causing more creosote in the chimney. But there would be some residual energy output in the form of heat.
Any special trick to getting them "dried" ?? Can't stack them like firewood, so wondering if there's a neat way to get things dried out. I've got a combination of dead & semi dead wood so, things are not completely dry. Is putting them in a 50lb paper bag the norm ??
   / Burning Wood Chips/Scrap #5
I used empty sunflower seed bags, 50 pounders. Guess you could just dump them in by the pail full or shovel.
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
Adams 5T HC Spreader (A55301)
Adams 5T HC...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A51406)
2012 INTERNATIONAL...
