Bullet heaters
   / Bullet heaters #1
fatjay
Veteran Member
Eastern PA
Not enough
For years I've been using k1 in my kerosene bullet heater. Last gas station with it shut down, and now I can only get it by the gallon at TSC for $13.99/gal which is insane. I burn 8-10 gallons a day when I'm in the shop, and that's pretty expensive. I was looking at multi-fuel heaters to try and find one that I could use diesel in, but they were $300+, so I didn't love that.
Then, I happened to be looking at my heater and it says kerosene OR #1 fuel oil, and I thought wait a minute, that's diesel. But does that mean I can use either type 1 or 2 diesel? All the pumps have switched to the winter blend around here.
Any suggestions?
   / Bullet heaters #2
I’ve been burning #2 diesel in my bullet heater (listed as use Kerosene only) for years without a problem. When they went to low sulfur it worked good with minimal smell.
   / Bullet heaters
That's quite reassuring, thanks. I didn't mind burning k1 because the price was fairly similiar to diesel, but now just doesn't exist anymore at the pump, and that's quite annoying.
   / Bullet heaters #4
Any time I've put diesel #2 in my bullet heaters, they would stink, and more fumes would build up in my shop. I won't use it any longer.
Also, I've had others who have used #2 say they have had spark plug problems using #2.
SR
  • Good Post
Reactions: JJT
   / Bullet heaters #5
Having been a reloader in the past, I wondered just why the hell you would want to heat bullets.
   / Bullet heaters #6
I burn diesel in mine also. No difference whatsoever. Work all day in an 800 sq.ft. shop with 8 ft. Ceilings. If it smelled or the fumes were bad, I wouldn't do it.🍻
   / Bullet heaters #7
I have separate kerosene and propane bullet heaters. I use ORD (#2 diesel) or propane, whichever is cheaper.
I do notice some odor with the ORD but the barn is ventilated enough so it isn't a problem.
I used to use the kerosene bullet in the shop which is attached to the house. the fume buildup was a problem there so I switched to the propane heater. I did get some condensation on really cold days though.
This spring, I installed a mini split unit in the shop. I now get heat and A/C, and at current prices, it costs less than either diesel or propane. Unfortunately, a mini split wouldn't work in the barn so I keep the bullets.
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
2006 CATERPILLAR D5G LGP CRAWLER DOZER (A51242)
2006 CATERPILLAR...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2016 GEHL RS5-19 TELESCOPIC FORKLIFT (A51242)
2016 GEHL RS5-19...
