Building with railroad rails
   / Building with railroad rails #1
bcp
Super Star Member
SW WA
Kubota BX2360
Every once in a while, someone will mention building a bridge or some other thing using railroad rail for strength. Rail is far more flexible than most people think, Many people are only familiar with short lengths, but long pieces are different. :)
Watch this video from about 6:15 to 7:50. It is a telephoto view that exaggerates the flexibility, but is still surprising.
Bruce
   / Building with railroad rails #2
Ribbon rail...
   / Building with railroad rails #3
I have a piece here that will probably never get used. I have seen them drop and break.
   / Building with railroad rails #4
I once saw a pole building a guy built, using railroad rails...
SR
   / Building with railroad rails #5
Steel composition is a malleable mixture, designed to be flexible. For bending moment elimination they have to set on a structural base that is also somewhat flexible; as wheels go over it there is constant vertical movement as weight goes off and on. As they flex and crystallize, they have to be replaced before they fail. Cracked rails lead to derailments.
Vertical, like the pole barn is OK. Building will flex well in a wind storm.
Ron
   / Building with railroad rails #6
I don`t know about bridges out of rail, but I made an anvil out of a bit about a foot long, and its handy for little jobs.
   / Building with railroad rails #7
I toured a mill nearby that produces rail. They ship in 1,400 foot lengths!
   / Building with railroad rails #8
There's a big difference in the flexibility of the same rail, comparing it at 4:30 and at 6:30. At least it appears there is.
   / Building with railroad rails #9
I've read a couple of times that rails are never sold. If this is true, there are an awful lot of ameture blacksmiths pounding on stolen rails.
   / Building with railroad rails #10
The building I work in has overhead cranes and they run on the same rail. A few bits leftover were quickly swept up by the blacksmiths!
2021 New Holland C327 Compact Track Loader (A52748)
2021 New Holland...
434669 (A48836)
434669 (A48836)
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
