Doug,
I think the problem if trying to figure out how much air flow to have is because the ground holds moisture and figuring it out is really going to be a case by case basis. Your soil may hold allot of moisture, or it might drain quickly. Sand versus clay type of thing. Your plan sounds well thought out, but the only way to know if it's working is by waiting a year or so and then to start doing periodic inspections. The deck that I was under doesn't show any signs of moisture under it, but while under there, it was overwhelming. They have a real problem that I told them about, and he told me he knows about, but that's as far as we got. I think they are just going to ignore it and hope it goes away by itself. I see this allot, and it keeps me in business, but it's still frustrating to deal with. Plastic on the ground should help, but in the few cases that I've seen plastic on the ground, it's been a mess and not actually doing anything. Mobile Homes do this, so I'm not sure how effective it is. In theory, it should work if done right, but for whatever reason, I always see it unrolled in areas, shoved into other areas and missing in others. Under the plastic can be very wet, or very dry, it's always a suprise to me when I come across these things.
Northern Tool sells electric fans with moisture sensors that I've installed. I'm not sure how effective they are, but don't see any real negatives to using them if moisture is an isssue. The times I've installed them, they seem to help, but don't address the real problem of stopping the moisture from getting under the house. Some clients like to go through the steps of trying everything but addressing the real problem. I give them my advice and then do what they are paying me to do.
Eddie
