building a skidding winch
   / building a skidding winch #1
billynphilly
muskoka,ontario,canada
kubota,L3400
I am going to build a skidding winch and am looking for free advice from anyone with experience.I am looking at using either the ramsey patriot 9500 with blue synthetic winch rope,or the mile marker 9500 both 12 volt.Making a skidding plate from 1/4 seel.Not sure on the synthetic with the rocky terrain so I may use galvanized cable.Any help is apprecated and thanks much.
   / building a skidding winch #2
Welcome to the forum
Skidding winch for what? Logs?
What size and weight material are you planning to winch in with this setup?
What will the winch be attached to?
Your profile filled in would really be great. May even help come up with some answers. /forums/images/graemlins/wink.gif
The pine logs will be 20" average wih a 20' max
The hardwood logs will be 18" average and 17' max
the tractor is a 35 hp 4x4 and I have 50 acres and am in no real hurry.Thanks
   / building a skidding winch #4
Don't use synthetic. It is great for vehicle self recovery as the rope just lays and the winch reels it up.
If you have a hydraulic remote on your tractor you may want to look at going hydraulic.
Deerlope has built one using a hydraulic milemarker and I'm building one with a hydraulic Warn.
   / building a skidding winch #5
building a winch pad huh...sounds like a good plan for your needs. I would go with 1/2 " plate steel, then use only aviation cable, don't forget to have block % tackle too. But this is only my opinion....
   / building a skidding winch #6
There is a good chance that your electrical system will not handle an electric winch. Current draw can be over 400 amps, that is a big gulp of battery power for a truck. I do not know what size battery you have in your tractor or what your charging system is rated at but I believe that the hydraulic winch is the way to go too.
I have a warn ti 9500 on my TJ. I have brought that thing to a dead stop with 3/4+ of the cable out. Cable safety is the most important thing always use a parchute /forums/images/graemlins/cool.gif I am guessing thats why you wanted syn rope. Slozuki discounted if for this because of the draging potential of the rope. I would agree with that.
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
