Building a deck on wagon gear
   / Building a deck on wagon gear #1
Tim_in_IA
Platinum Member
Eastern Iowa
Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
I just saw the post "Re-Decking a Trailer" and it made me think of a project I would like to tackle. I have an old wagon with sidewalls (think it was used for grain and a chain across the middle that holds the sides in under load. It has electric brand wagon gear, and a nice dump cylinder. The only problem is the floor and wooden supports are shot. I would like to replace them but I wasn't sure what wood was best to use for this? Are there plans anywhere that detail how to build a deck on wagon gear and what wood to use? I would like to retain the original dimensions and plan so I can still use the old sides as they are a combination of rivets and metal bracing, and the wood is just faded but still good.
What I would like to do is remove the sidewall assemblies and replace the support (joists?) with something suitable and then redeck and reattach the sides. Can anyone recommend a wood species for this?
   / Building a deck on wagon gear #2
White oak would be your best bet.
Look for a sawmill around that can cut you some timbers, and some cross supports. Then deck the floor with treated decking.
That's great! I have some nice white oaks on my property and a neighbor with a sawmill /forums/images/graemlins/smile.gif. I guess I just use an identical dimension to what was previously there?
2012 Ford F-350 Omaha Service Truck (A51692)
2012 Ford F-350...
2009 GMC Passenger Van, Vortec Engine (A52384)
2009 GMC Passenger...
Autocar Xpeditor Tri-Axle Heil Front Loader Garbage Truck (A51692)
Autocar Xpeditor...
CAT Skid Steer (A50322)
CAT Skid Steer...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
