woodlandfarms
Super Member
- Joined
- Jul 31, 2006
- Messages
- 6,139
- Location
- Los Angeles / SW Washington
- Tractor
- PowerTrac 1850, Kubota RTV x900
My machine is a much like a skid steer, all implements in front. But at the end of the day we spend a lot of time driving backwards when using a box blade or land plane. So I am designing out a 3PT hitch that would be temporarily installed (needs to be light to be easily removed).
I wanted to ask you who have 3pts about the value of the following, (and the value based on just using a box blade / land plane. All other accessories are front mounted and work well. I will never put other implements on back (Post Hole Diggers, tillers) as the front mounts work really well)
Two way valves on the up and down motion. Is it important to be able to push down on the implement?
Hydraulic tilt. I get it makes tilting easier but is it that big of a deal getting off the tractor to adust level
Hydraulic top. As I am dragging my implements, what value would a hydraulic top have.
Most of my questions are due to economics. I don't have a lot of cash (If I went crazy, this could be a $1500 build with cylinders, controls, hoses). I am limited on real estate so I am going to have to use electric valve controls and I want to limit them due to costs.
Thanks for your ideas in advance.
