Build My Kubota?
   / Build My Kubota? #1
PSDStu
Platinum Member
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
For the L series Tractors, does anyone know what these various Hyd Remote Valve abbreviations mean?
(1) Standard Valve with Lever Kit
(1) Standard Valve (1) DV with Lever Kits
(1) Standard Valve (1) FD with Lever Kits
(1) Standard Valve (1) DV (1) FD with Lever Kits
(1) Standard Valve (2) DV with Lever Kits
(1) Standard Valve (2) FD with Lever Kits
Just not sure what the DV and FD mean?
   / Build My Kubota? #2
WAG here.. but float and detent? for F & D ???
again.. just a WAG..
soundguy
   / Build My Kubota? #3
double acting valve and float valve, hope this helps
   / Build My Kubota? #4
Sweet, now what do those mean? lol
   / Build My Kubota? #5
The double acting gives you two way hydraulic power for cylinders. The Float will give you a detent to allow what the cylinder is hooked to to go up and down as it needs so you have no down pressure on the implement and it can accomadate changes.
   / Build My Kubota? #6
A float valve will do everything a Double action Valve will do and additionally will float as described above.
   / Build My Kubota? #7
Yep.. On my NH.. you have fore/aft on the remotes for DA.. then if you kick the handle all the way forward.. it goes into float.
soundguy
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
