Build it yourself subframe mount backhoe
   / Build it yourself subframe mount backhoe #1
deere_x475guy
Eaton Rapids, MI
JD 4110
Hi gang. I have been searching for bachhoe plans that are subframe mount and not 3 point. So far no luck so I thought I would ask here. The cadplans and one other look all to be 3 point.....
TIA
   / Build it yourself subframe mount backhoe #2
Do you really want to build the BH yourself?
Don't know if Deere makes subframe mount BHs anymore. My subframe BH is JD, but is not a current model and is not designed for my tractor. I had access to it at the JD dealer for taking measurements. I welded and cut the subframe, and made brackets to fit my tractor.
I am pleased with the result, but that was enough work for me. That was 3 or 4 years ago. Everything is holding up so far.
Adapting an existing subframe BH to your tractor is just an option that you may not have considered. A JD #7 BH is a subframe model that might be adaptable to your tractor. They aren't in production anymore, but your dealer could do a search and see if one is sitting around somewhere at another dealership. Even a NH or Kubota model might work just fine. You would almost have to see it first, measure the critical dimentions, then decide if the project is feasible. It might very well be easier than building the whole thing from scratch.
OkieG
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
More info coming soon! (A50323)
More info coming...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
Unused Delta Crash...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
