Build hyd toplink with check valve
   / Build hyd toplink with check valve #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I decided to go with hydraulic toplinks on two or three tractors and want to prevent leakdown of the cylinder so I guess I need a check-valve built into the system. One on each line.
Rather than buying cylinders with a check valves built into each one as a unit, why couln't I just buy two checkvalves and make into quick-attach units that I could snap into my outlets when the need required?
This way I could save $$ and make my life easier.
Surplus Center has seveal--one is Gresen #9-1019 @$19 or Sterling Hydraulic @ $9
Seems like a great idea?
Any thoughts on this?
   / Build hyd toplink with check valve #2
Those check valves you referenced are NOT POCV's (Pilot Operated Check Valve's), they are just flow check valve's-totally different theory of operation.
THIS is an example of a POCV. You will not find the equivelent of what CCM sells sold in the USA for anywhere near the price they offer. This has been gone over here on TBN hundreds of times before...
KennyD--
Thanks for the advice. Point is taken.
2003 Big Tex 10PI...
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
