Bucket wont curl up
   / Bucket wont curl up #1
JackMentink
Rolla, Missouri
2008 Montana R3644
I have a montana r3644 and when I was pushing some snow for an extended period of time (2 hours) in some pretty cold weather for Missouri (10 degrees with 20 mph winds), the loader joy stick wouldn't allow the bucket to curl up. The joy stick is leaning in twords the seat at a strange angle and the bucket wont curl up. Everything else works great. Can lift the bucket, 3 pt works up and down. Any body ever have this happen.
The loader joystick is the type that if you move in front back it raises and lowers the bucket and if you move it side to side it curls the bucket.
I read a previous thread about a similar problem with a montana, but they were talking about wter getting in some caps. When I pulled the boot of off my joystick, I have no caps. I have plate with a ball bearing in one corner. I haven't put the heat to it yet, but I have had it in an insulated garage for 36 hours (40 degrees) and nothing has unthawed and become functional yet.
Any solution or word of wisdom from anybody?
   / Bucket wont curl up #2
the caps are not under the boot, the caps are at the bottom of the valves.
   / Bucket wont curl up #3
Check out the mechanical aspect of the joystick. Perhaps some linkages have come loose?:confused:
   / Bucket wont curl up #4
I had the same problem with my R4944. An Allen head cap screw fell out of the bottom of the joystick housing. I was lucky, it was in the snow on the platform. I check these cap screws every so often.
Thats exactly what happened. The allen headed screw came out of the stationary ball that the lever pivots on and caused it to not move properly. I put the screw back in and put the ball back where it was suppose to be and everything works great.
   / Bucket wont curl up #6
lock tite should stop that from happening would'nt go any stronger than the blue.
SKID STEER BUCKET (A52472)
SKID STEER BUCKET...
John Deere 335 Round Baler (4ftx4ft) (A52748)
John Deere 335...
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
