Bucket wagging
   / Bucket wagging #1
arrow
Super Member
Foster, RI
Mahindra 3016
I have a 23 yr old JD 750. Its worked hard all its life. After I dump a load out of the bucket, it wags on its pins like it isn't connected to the cylinders. It also takes a while to respond to full dump position after the load is out and I'm trying to clear the last material out of the bucket. Does this signify some type of cylinder failure?
   / Bucket wagging #2
Well, I'm more than double the age of your 750 and I "wag on my pins, too"!
I'd guess that you've got some pin slop. Especially if the bucket clanks on the dump as well as the tilt back. The cylinders might be a bit tired, too. If you've got some leakin' and drips - that's a good indicator that a cylinder rebuild is in order -- IMO.
Your main hydraulic pump could be gettin' a little slow on the go, too. How's the steering response (I can't remember if the steering is separate from the implement pump) and the 3pt lift response? Are they a bit slow to respond, too? If so, then a rebuilt pump could be just what yur trusty 750 needs as well.
Best of luck.
AKfish
2020 MACK GRANITE GR64B DUMP TRUCK (A50459)
2020 MACK GRANITE...
(1) 10ft Livestock Panel (A48837)
(1) 10ft Livestock...
2008 Honda Civic Sedan (A48082)
2008 Honda Civic...
New/Unused 2025 CFG H15R Mini Excavator (A48837)
New/Unused 2025...
2022 JOHN DEERE 317G SKID STEER (A50458)
2022 JOHN DEERE...
New/Unused Quick Attach Pallet Forks (A48837)
New/Unused Quick...
